Thanks,
TheMidge
^ This.hambini wrote: ↑Sun Feb 18, 2018 12:06 amIf you have hardened bearings against an aluminium axle it is going to leave track marks on the surface.
I don't think it's categoric to say it's in terrible condition and should be thrown away without measuring it and having a look at the track marks. You really need a better picture.
Hambini
The uploaded resolution is 640 x 480 and I'm looking at it on a monitor that is 4k.
This is good guidance and I'd add to take the photo at higher resolution if you are going to upload it.TobinHatesYou wrote:
1) Clean as much gunk off the spindle as possible.
2) Get a better FoV with your camera...closer and not an oblique angle
3) Put a sheet of white paper under the spindle when you take the photo.
If you buy decent bearings they are always hardened. The best way to stop the track marks is use a bottom bracket that has been designed with a sleeve between the bearing and axle (Shimano). On 30mm axles it's usually a direct fit between the axle and bearing in which case my suggestion would be to buy bearings that are a decent fit.jlok wrote:how to avoid those track marks? softer bearings?
