Help, fitting a THM fork into Colnago frame
Nazhemie
by Nazhemie
Hi everyone, i have a THM fork from a Cervelo R5Ca 2011 1 1/8“ – 1 3/8“ . I want the fork to fit into my Colnago Strada SL 2014 1 1/8" - 1 1/4" . I believe that the Cervelo R5Ca frame headset is Integrated while the Colnago Strada SL is Semi-Integrated headset frame which need to put the bearing Cup to install the headset and fork.
I cannot fully insert by previous lower headset bearing which is Ritchey WCS Press Fit 1 1/4 which have Internal Diameter bearing of 34mm into the THM lower fork tube which is 36mm. I tried the Cane Creek 1 3/8 36x45 bearing which have ID of 37mm. Which headset is suitable for my Colnago with THM fork?
THM Cervelo R5CA 2011 fork 1 1/8 to 1 1/4"
Upper fork tube diameter 28.6mm
Lower fork tube diameter 36mm
came along with Cane Creek 1 3/8" bearing
ID 37mm , OD 49mm
Colnago Strada SL 2014 fork 1 1/8 - 1 1/4"
Lower fork tube diameter 33mm
Using Ritchey WCS ZS49/33 Lower bearing 1 1/4" bearing
ID 34mm, OD 45mm
Someone use a CK headset to fit the fork.
If CK headset will do the job,which one i need? Inset 3, Inset 5 or Inset 7 ?
Or there any suggestion ?
Specs
Weight
Details
CerveloTHM
Starnut
My Colnago Strada SL Italia stripe Tri-Color.
With Shimano Ultegra R8000.
Named it Colnago SLR8 ( Accelerate ) :P
7676 grams
Colnago Fork with Ritchey WCS Lower 1 1/4"
Colnago Strada SL 2014 7.6kg
Ultegra R8000
Specialized Venge S-Works 2012 7.5kg
Dura Ace 9000
Wheelset : Farsports Ventoux C5 clincher 1.39kg
kdawg
by kdawg
You say at the top at its 1 3/8 then further down that it’s 1 1/4. I’m assuming it’s the first one and that’s why it won’t fit - it’s bigger.
I’ve seen headsets to fit a narrower steerer - but never a bigger one.
I'm left handed, if that matters.
Nazhemie
by Nazhemie
kdawg wrote:
Wed Feb 07, 2018 9:55 am
Upper section tube measurement for both fork is 28.6mm means 1 1/8
Only lower is different
For colnago fork is 33mm
For thm fork is 36mm
This may help
Side to side
Left is colnago
Right is thm
Measurements
Colnago lower headtube 48.6mm
Ritchey wcs cup 49.35mm
Ultegra R8000
Dura Ace 9000
Lelandjt
by Lelandjt
I've never seen someone get a fork into a frame that's made for a smaller fork. Your THM is 1/8" too big for the Colnago.
Nazhemie
by Nazhemie
Lelandjt wrote:
Wed Feb 07, 2018 12:08 pm
No it can fit fine to the frame but the lower bearing is the problem..
Ultegra R8000
Dura Ace 9000
glepore
by glepore
Assuming that the Colnago has a 49 mm non tapered headtube, nothing you've looked at works. The inset 5 is 49mm but it only works with 1 1/4-1 1/2 tapered. The 1 /3/8 is VERY oddball. The only other bike I know of that uses one is the Speialized Allez Smartweld which uses a 49mm semi integrated bearing for an 1 3/8 fork crown. Search for that bearing - Cane Creek might have one but they just redid their website and the bearing finder tool is gone. The only other solution would be to buy and adapter that adapts crown race of 1 1/4 fork to a 1 1/2 bearing (those headsets are common, inset 5 works) and have a machinist mill it out from 1 1/8 to 1 3/8.
viewtopic.php?t=130531
https://forums.thepaceline.net/showthread.php?t=149417
Honestly, its a holy grail type thing.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
elfuinha
by elfuinha
glepore wrote:
Wed Feb 07, 2018 6:16 pm
The Thm fork will need a 1 1/2 bearing.
i use a CK inset 7 on my bike with this fork.
glepore
by glepore
Ok, with no crown race-ie the fork has an integrated crown race ?
Nazhemie
by Nazhemie
elfuinha wrote:
Thu Feb 08, 2018 10:54 am
I see, do you have some pictures of your bike with the THM fork?
Inset 7? but i cant use it because the lower is EC44.
I may use Inset 3 & 5 because of my frame lower headtube diameter are 49mm and the THM fork is 1 3/8 or i assumely think it was 1.5"
I tried CANE CREEK HEADSET ZS44/EC49 in my LBS but it wouldn't fit properly into the frame because inside the lower headtube, there were some like stopper for the lower cup to be seat on. So i need to get custom machine cut for it to fit into the frame. So i just think about finding a ZS49/40 not ZS49/30. (currently using ZS49/33)
need to cut
So i found a FSA and Da Bomb. I choosed fsa and already purchased FSA Gravity 4
brand:FSA
Content: 1 piece
Material: Aluminium, stainless steel
Surface finish: anodisized
fork steerer size: 1.5" tapered
S.H.I.S.: EC49/28.6, ZS49/40
headset type: external, semi-integrated
I just get the lower headset only
DARTMOOR Dive Headset ZS44/28.6 I ZS49/40
Ultegra R8000
Dura Ace 9000
Nazhemie
by Nazhemie
glepore wrote:
Thu Feb 08, 2018 1:40 pm
Yes, integrated crown race . Bearing 1 3/8 fitted half way and 1 1/2 bearing fitted fully.
Ultegra R8000
Dura Ace 9000
