DI2 bar end junction without holes in bar
gbrown
by gbrown
I've just bought a new Trek Domane SLR 9 Disc with R9170 di2 and the shop are prepping it for collection. The mechanic has fitted a bar end junction, even though the Bontrager carbon bars aren't drilled, by taking a single di2 wire down the underside of the bar to the right shifter. I popped in today to take a look before the bar was wrapped, and grabbed some photos.
So he's used a single short cable, taken from the under stem junction box no longer being used, to run from the bar end junction, looped it back inside the bar end and squeezed it down the side of the junction box and then looped round and taped it under the bar to run up to the shifter. The bar tape will then completely cover it.
He then used a y-cable to run the long ends between the shifters along the outside of the bars as normal, along with the hydraulic brake cables. The short tail of the y cable will be tucked into the stem, through the opening under the bar and connected to the WU111 wireless unit. The cable from the bottom bracket that went to the old junction box will then also be tucked into the stem so it will all be very neat and tidy.
My first thought was that the cable would be crushed or pinched when squeezed between the bar end and the bar, and turned sharply back on itself, but all seems to work well and passed all diagnostics. Once taped up, it should look very neat.
Has anyone else done it this way?
Cheers,
Geoff
pdlpsher1
by pdlpsher1
Yes. There are several videos on YouTube describing this method. But this is the first time I’ve seen a wire go inside the bar not via a small hole drilled near the end of the bar. I had considered this method but ultimately I decided to drill two holes on my bar.
Congrats on your new bike.
rlanger
by rlanger
gbrown wrote:
Mon Feb 05, 2018 5:46 pm
Cheers,
Geoff
Have you had any issues with this setup Geoff? Looking to do this on my bike next week.
Thanks.
gaspard123
by gaspard123
thought I would give this one a bump to check on long term durability of this solution. Most of the traditional bars I'm interested in are not yet drilled, and while I'm not entirely opposed to getting the drill out, was just curious if this one had worked out. thanks in advance
Dokas
by Dokas
The di2-line does not appear to be good for the possibility of being cut in the event of a collision
avispa
by avispa
If I’m not mistaken, this is the way it’s done with non-drilled bars. And one reason Shimano provides a “dummy” cable with the EW-RS910 so that a mechanic installs it on the opposite side of the bars and the rider does not feel as if one side there’s a cable and on the other the bars would feel smooth.
One reason some frames also have a second installation location for the RS910, such as the down tube, is to clear the bars from junction boxes.
I think in case of a collision where your bar ends take the brunt of the impact the RS 910 most likely would be damaged.
There’s really no risk on drilling holes in bars or frames. The only thing is that it voids warranties and nobody wants to take responsibility (rightfully so) for possible problems .
bedampft
by bedampft
Cheers,
Geoff
Only problem with this setup is, you can't use extra shifters on one of the STIs.
I'm going to drill one hole near the barend in my Easton Carbon Dropbar tomorrow. Then i'll route one short wire on the outside of the bar to the right STI and the Y-cable between the other STI and the bar end junction. In this case i still got one port left on each STI for extra shifters. But i'm still a little mad that Shimano has lost the sprinter ports on the ST-R9170.
Sjazzzzy
by Sjazzzzy
bedampft wrote:
Mon Nov 19, 2018 12:04 am
Checking in, how’d this turn out? I’m thinking of drilling my Eastons as well.
ryanw
by ryanw
It's beyond me why these £10k bikes don't have full internal routing on the bars?!
My S5 disc Di2 has the wires running down the back of the bars into a hole near the end of the drops. You can feel the wires when you squeeze the drops, not great at all...
I had the V2 Enve aero bars on my old S5 and all was internally routed to the barend port. Very neat.
'16 Cervelo S5 - 6,650g RIP
'17 Focus Mares Force 1 - 7,170g
'19 Cervelo S5 Disc - 7,460g
IG: RhinosWorkshop - Check it out for all my custom builds :thumbup:
:!: Ride Southern Spain Cycling Holidays *£445 for 7 Nights* :!:
