New cannondale SYSTEMSIX road frame!
scapewalker
by scapewalker
I have seen Hi-Mod Dura-Ace being sold for as little as $7700 which makes it a really interesting proposition at this point.
I guess they have not been selling as well as Cannondale would have hoped.
danridesbikes
by danridesbikes
anyone know off hand what length SRAM flatmount bolts i need, switching from Shimano ultegra that came stock to Red AXS Calipers
and is it wrong that it winds me up that the fact the SRAM eTap blank for the downtube port is 3k weave
thanks
Dan Gerous
by Dan Gerous
Not a fan of weaved carbon either, always looks like a cosmetic pattern to 'look' carbon like we were still in 2003! But I can't say that the switchplate is big enough to bother me much (I have less though as I use the Di2 plate on my Evo)... But you could easily paint it black... or match the frame depending of the color.
cerro
by cerro
danridesbikes: Not sure about the size but same as Shimano or a millimeter less :)
/jonas l
johnsonmoog
by johnsonmoog
Can anyone tell me how easy it would be to either switch chainrings on the crankset, or swap out the standard chainset for an Ultegra crank (will it need any adapter or new BB cups?).
Many thanks.
ajcav86
by ajcav86
Weight?
Perdita- Burls Ti Road
Aurelia- Saffron Stainless/Carbon Gravel
Bertha - Trek Speedconcept
Jolene - Over kill winter bike
danridesbikes
by danridesbikes
8.120kg/17.90lbs
saddles a base model dimension, will switch it to a lighter version if i get on with it, or maybe an sworks power, need some sort of way of mounting a rear light with the saddle slammed forward
ajcav86
by ajcav86
Is the frame high mod?
danridesbikes
by danridesbikes
no its the base model, i got it on closeout for £1999 and stripped everything out
young
by young
like the 1x and waxed chain!
I got 48 10-33 and 44 10-33 myself
danridesbikes
by danridesbikes
cheers, its Moltenspeedwax
its pan flat here, i could do a 100m loop out the door with less than 300m climbing,
and the 50t was super cheap
Peeza21
by Peeza21
Need to fix that saddle tilt.
Cannondale Systemsix Ultegra 2020 8)
viewtopic.php?f=10&t=160844
req110
by req110
DamonRinard wrote:
Mon Oct 29, 2018 12:05 am
Hi gwilson,
Glad you like your SystemSix!
The axle you linked won't work, because Speed Release axles are M12x1 double-lead thread, while most trainer axles are single lead. (The double lead is what makes Speed Release twice as fast to install: half the turns.)
But there's a workaround. Install this RD hanger, Cannondale part number KP419/, and the axle you linked seems like it should work.
https://www.cannondaleexperts.com/Canno ... _5509.html
This hanger, originally designed for Slate and Beast of the East, has single lead threads, so it fits the trainer axle. One nuance is the rear hub axle sometimes jams on the hanger's inside boss, but slip it past and it works.
As usual, be sure the trainer axle fits the left dropout as well. Speed Release is flat, while some others have a cone.
Cheers,
Damon
I have my systemsix on the trainer, just using Elite Thru-Axle Adaptor for Cycle Trainers for 25 euros. No need to hassle with RD hanger. It's design is not nice, but acceptable for inbood usage.
TurboKoo
by TurboKoo
SystemSix was again fastest on German Roadbike magazine (05/20) testing different aerobikes.
Fast, faster, SystemSix
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
