New cannondale SYSTEMSIX road frame!
These paintjobs are really... bad.
refthimos
by refthimos
It looks like we might have a decent computer mount available soon:
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
matvalse
by matvalse
kgt wrote:
Sat Jul 27, 2019 8:12 pm
You're right
eric01
by eric01
The first few are ok. I like the EF purple one. But that last peach colored one... that’s terrible. I’m curious how many of those they’ll sell
Specialized and trek are killing it with their paint jobs. Too bad Cannondale are just meh
DVR
by DVR
metyl wrote:
Thu Jul 25, 2019 3:16 pm
@DVR @C36 where can I get this zero setback seat post?
Thanks
@ your local Cannondale dealer, should be available in the coming weeks/months.
Cannondale SuperSix EVO HM eTap
Cannondale SuperSix EVO HM Disc Ultegra
Cannondale SystemSix eTap AXS
Colnago C60 eTap
Pinarello Dogma F8 eTap
wrenegade
by wrenegade
The branding/graphics on the Hollowgram Si crankset is bad. Just bad. The SiSL2 still looks great, what was wrong with the Si crank arm looking almost the same?
Paint is better than last year, though almost anything would be, but ya it is still bad. I'm a huge Cannondale fan but I don't think they've had a good paint job since 2016 on anything (stock). The new Supersixes are only ok (apart from the EF one which is nice), but pretty bland. Totally agree that Trek is killing it. Specialized are good, they're "safe" but certainly nothing to complain about.
I still can't get over that little notch between the fork crown and the bottom of the headtube. Something just seems wrong. I don't care how fast this bike is the looks would keep me away. Oh well.
Kingston
by Kingston
DVR wrote:
Wed Jul 31, 2019 5:00 pm
Thanks
I got this reply from European distributor (via local dealer)
K26080 is the one for the 15mm offset, which looks like 0 offset.
So the european dealer doesn’t know.
Lynet
by Lynet
@damon
I have quite an issue with chain drop. It occurs under heavy load (sprinting, starting from a standing position) and when in 52/11 combination. I have the stamdard setup with FSA 52/36 rings and 11-30 cassette. Have tried new chain, other rings (Praxis Works) and other wheels as well. Still chain drop when sprinting in the 52/11 combination.
Is this an issue you are familiar with?
TriJoeri
by TriJoeri
I've searched through this thread already and read that a few of you that are 5'7" with a 30" inseam have the 51cm. This apparently comes with a 400mm handlebar and 100mm stem, and 172.5mm cranks.
Right now I have a size 50 (525mm top tube) Pinarello Dogma 65.1 Think 2 with 1cm spacer under the stem, and a 100mm -17 degree stem. Saddle tip is 22mm behind the bottom bracket, with 170mm cranks. Stack is 520mm for both frames, reach is 7mm more on the SystemSix while the top tube is 4mm longer than the Dogma.
I'd just like to make sure that this is achievable on the SystemSix before I buy one, without needing too many spacers (likely won't be an issue) or without needing a ridiculously long stem..
peted76
by peted76
TriJoeri wrote:
Thu Sep 12, 2019 10:08 am
172.5 cranks on a small bike seems a bit mean of them!
TriJoeri
by TriJoeri
peted76 wrote:
Thu Sep 12, 2019 10:48 am
Haha my thoughts exactly, seems strange they would put anything more than 170mm on the smallest sizes..
slashy
by slashy
on the EVO 2 supersix size 52 , also 172.5 mm cranks. (and a huuuuge handlebar too if I remember correctly / sold the bar before riding it)
ajcav86
by ajcav86
Looking into a system six. Will run 25mm conti 5000s.. do I go Knot 64 or Enve 5.6? Which will be faster with these tyres? Damion?
Perdita- Burls Ti Road
Aurelia- Saffron Stainless/Carbon Gravel
Bertha - Trek Speedconcept
Jolene - Over kill winter bike
TobinHatesYou
by TobinHatesYou
ajcav86 wrote:
Wed Oct 09, 2019 7:03 pm
The KNØT 64s will almost surely be faster based on the additional 1cm of front rim depth.
RedbullFiXX
by RedbullFiXX
C-Dale should take some heat for how poor they look in the photos
I've seen a few Supers, and Sytems in the wild, and they look sharp
Cyclocross, in general, is about riding the wrong bike for the conditions.
