New cannondale SYSTEMSIX road frame!
Stitchking
by Stitchking
TLN wrote:I was looking at different bars, and it looks like Madone bar might be a good choice. It's one piece, so you lose adjustments, but cable route all the way through the stem.
Having a Madone bar on Cdale is a different question though.
This won’t work with that steerer. Vision metron 5d is what ef have been using
bikesrdangerousmmk
by bikesrdangerousmmk
Posted a while back but didn’t notice a reply.
Damon, how would enve 4.5 ar rims work here with 28 nominal pro ones inflated to about 30mm actual
DamonRinard
by DamonRinard
bikesrdangerousmmk wrote:
Sat Nov 03, 2018 10:54 pm
Hi bikesrdangerousmmk,
For selling, ISO says we have to have minimum 4 mm clearance, which means I can officially recommend tires up to 28 mm measured width.
However, after the bike is sold, you can run whatever tires you like! If you're okay with less than ISO clearance then go for it. There's a guy in our office running a similar setup (ENVE ARs and some wide tires), but I don't know if he's ridden through any sticky mud yet, ha ha!
Cheers,
Damon
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
bikesrdangerousmmk
Thanks, Damon
TLN
by TLN
Quick question about KNOT54 wheels:
What hubs are those, can I convert to other axles in future? Or QR if I decide to use on older bike? I hope it's standart DT-swiss internals
Chaingobbler
by Chaingobbler
TLN wrote:
Thu Nov 08, 2018 6:20 pm
I read that it is standard DT Swiss internals, I think they said specifically 240’s, however the front hub is also a new proprietary design. Maybe Damon can chime in on the possibility there.
DamonRinard
by DamonRinard
Hi TLN,
Chaingobbler is right: The rear hub has normal DTSwiss 240 internals, including axles & endcaps, so you have all the DTSwiss 240 axle and endcap possibilities.
The front hub is our own design (to reduce size and therefore weight and aero drag as much as possible). We don't make any other endcaps, so it's always as designed: 12 mm through axle.
But please be aware: the rims are NOT rim brake compatible, neither from layup & resin perspective nor dimensionally. The composite rim has no rim-brake properties (no high-temp resin, etc.), and at 32 mm wide, I don't know any rim brake that could accept it.
Bottom line: enjoy the Knot 64 wheels as originally sold: awesome through-axle, disc-brake only wheels.
Cheers,
Damon
Damon Rinard
gwilson
by gwilson
has anyone figured out a good way to attach a rear light yet (other than on a saddle bag)?
ianeire
by ianeire
The problem with the SystemSix.
Mep
by Mep
I miss Matt Stephens! He should totally be with the GCN crew.
Knokkelhaug
by Knokkelhaug
gwilson wrote:
Sat Nov 10, 2018 4:05 am
I use Lezyne KTV Drive rear light, with 2 rubber bands to fixate it (for Garmin Edge mount. Not easy to find single rubber band long enough). Looks good!
https://www.lezyne.com/product-led-sport-ktvrear.php
Stitchking
by Stitchking
Just going to leave this work in progress here... this is my colleagues bike we are building up while he recovers from a broken metacarpal. Its pretty gorgeous.
Sent from my SM-G935F using Tapatalk
TLN
by TLN
DamonRinard wrote:
Fri Nov 09, 2018 1:44 am
Oh, I totally understand that wheels are not rim-brake compatible. If I recall, there's a different spacing for rim-specific and disc-specific wheels.
My thought was if I can use KNOT wheels on QR disc-specific bike. I totally understand that I may not fit there with 32mm width, but it would be interesting to try. Of course, newer bikes are thru-axle, so it will be more or less future proof (if it fits with 32mm width).
refthimos
by refthimos
Stitchking wrote:
Mon Nov 12, 2018 7:19 am
Why the swap from the KNOT64 wheels?
EVO | 5.37kg
SystemSix | 8.01kg
TCR Advanced SL Disc | 7.35kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8 | Alto Disc
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
Dan Gerous
by Dan Gerous
refthimos wrote:
Wed Nov 14, 2018 2:19 am
This colorway (really nice by the way!) is only available as a frameset so, no Knot wheels to be swapped in the first place.
