New cannondale SYSTEMSIX road frame!
tommyg76
by tommyg76
CAAD - That's interesting to hear, do you mind me asking whereabouts you are based? Is this this the Dura Ace version?
wingguy
by wingguy
Which country are you in?
tommyg76
by tommyg76
I'm based in Princeton, NJ
CAAD8FRED
by CAAD8FRED
tommyg76 wrote:
Thu Aug 30, 2018 11:35 pm
Hollywood, Florida
Knokkelhaug
by Knokkelhaug
Have got my new SystemSix Ultegra. It is far better than expected! Even with original Fulcrum wheels and 23mm Vittoria it feels comfortable. The geometry is relaxed and the handlebar fits me well. Power transmission and stability are quite similar to SuperSix Himod. I have also tested the bike with 28mm tubeless. It's feels like a race version of synapse :-). The black/ red colored frame gives a lot of attention and positive feedback, same with the frame design. Recommended!
Knokkelhaug
by Knokkelhaug
I can't find a usermanual for this bike. Has anyone a link to share?
DamonRinard
by DamonRinard
Knokkelhaug wrote:
Sun Sep 02, 2018 9:28 am
Hi Knokkelhaug,
Normally manuals come with your bike. There should be two: the general owner's manual, and the SystemSix Owner's Manual Supplement (OMS). Can you check with your dealer?
Also, both will eventually be on the Cannondale.com website under Support, here:
https://www.cannondale.com/en/USA/Suppo ... nuals/Road
I just checked. The general owner's manual is there, but the new OMS for your SystemSix is not there yet.
Cheers,
Damon
Damon Rinard
Engineering Manager, Road Bikes
Cycling Sports Group, Cannondale
Ex-Kestrel, ex-Velomax, ex-Trek, ex-Cervelo
Knokkelhaug
by Knokkelhaug
I will contact the dealer. Thank you for quick respond!
wingguy
by wingguy
tommyg76 wrote:
Fri Aug 31, 2018 2:46 pm
Ok. I can't say for sure because I'm in a different market but there should be shops where you are with HM bikes. For us, the HM DA DI2 bikes we pre-ordered are due in a week, but anything ordered now will roll over to the second production which is going to be january/february time.
If you call or email Cannondale USA they would probably be able to tell you which shops in your general area had pre-orders of the bike you need?
candycycles
by candycycles
Hi,
We have few bikes HiMod Systemsix
Which size you are looking?
refthimos
by refthimos
Hi-Mod DA or Ultegra?
EVO1 | 5.37kg
EVO3 | 6.51kg
SystemSix | 8.01kg
P5 | 9070 Di2 | SISL2 SRM | Enve 7.8/FFWD Falcon | Roval 321
T1 | P2Max Type S | Rolf Prima FX58/Zipp Super 9 Disc
tommyg76
by tommyg76
Hi-Mod DA - 56
wingguy
by wingguy
DamonRinard wrote:
Sun Sep 02, 2018 11:27 am
Cheers,
Damon
Hi Damon - gonna hijack this thread for a couple of Superslice questions if that's ok! :wink:
First, the website has the crucial max/min pad stack and reach co-ordinates shown on the Geo diagram as measurements P,Q,R,S, but the chart hasn't been populated with the numbers, can your web guys get that data up?
Second, since the frame was presumably designed before the SystemSix, can it fit the same Knot 64 wheels or might it be too narrow? If it does fit, would they be as fast in the Slice as the Six, i.e. one of the best upgrade options for the DI2 model?
Thanks!
(BTW the Etap model page makes several references to a 12x148 rear hub. I'm assuming that's a typo and not the first sighting of road boost in the wild :P )
mrlobber
by mrlobber
^^^ this. Curious to know as well.
Retired bikes: Cervelo S5 2015 / Felt AR FRD 2014 / Cannondale SS HM 2014 / Scott Addict SL 2014 / Scott Plasma Premium 2014 / Orbea Orca 2008 / Look 596 /
CAAD8FRED
by CAAD8FRED
Hey Damon
A little unrelated to the SystemSix
In most independent tests the Scott Foil is right with the Venge and Madone, what happened in your wind tunnel tests that caused it to slip so low?
Rob
