Drilling Handlebars - Poll
Would you drill alu bars - at the tips, not at the shifter
I have done
11
22%
I would do
12
24%
I wouldn't
23
46%
Not sure
8%
Total votes: 50
Hexsense
by Hexsense
how about 3mm hole behind stem claming area?
the area that facing stem which normally face hollow hole part of the stem?
would it be fine on alloy or carbon?
Hellgate
by Hellgate
I've drilled old Cinelli and Mavic bars back in the day in order to use Modolo levers with the Modolo cable conversion kit. Worked fine. Used both bars for many years.
Sent from my ONEPLUS A5010 using Tapatalk
Butcher
by Butcher
Hexsense wrote: ↑
Sat Feb 03, 2018 9:25 pm
When I ran my first Campy EPS cables, I did just this. There was holes already in the handlebars for the normal cables so the cables entered the handlebar there. Drilling a hole behind the bar where it attaches to the stem is where the EPS cables exited. The inside of the stem is where I put the interface and the cables exited the stem thru the steering tube [yet another hole, but that was reinforced with extra carbon]. The cables exited the lower portion of the steering tube [again, another hole reinforced with carbon] so they could enter the inside of the frame.
I have done this on three bikes and never had a problem. The handle bar of choice is the K-Wing FSA. Why? because that is what I had, and so far, it has not broke. All three handle bars had several mm thick carbon at the clamp area.
sugarkane
by sugarkane
I've drilled alloy bars but I won't drill carbon. I also don't drill in the bends or near the shifter
