carbon bottle-cage with lowest position possible for bottle, which one?
garjo
by garjo
I got a pre2016 Supersix and I'm going to put on it a second bottlecage for a bottlebox where storaging my tools (minipump, spare tubular tyre).
But, In contrast to latest supersix models, my frame has the position for the 2nd cage too high and very little aero, so do you know what light carbon bottlecage could have the lowest position possible for bottles?
For lowest position I mean the maximun distance possible between the lower hole and the lower point which supports the bottle?
My 4,93 kg Supersix Evo HM: viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: viewtopic.php?f=10&t=134364
Tango
by Tango
Maybe the attached Ritchey bottle cage helps you. It height is variable, maybe you can do some math or search to get the range.
Another solution might be to use a cage like Elite Cannibal, which allows to take the bottle sideways.
TonyM
by TonyM
Why don't you use the Elite Cannibale bottle cage - also available in carbon (you can slide the bottle sideways):
https://www.competitivecyclist.com/elit ... arbon-cage
sun
by sun
Specialized says they designed the S-Works Carbon Rib Cage II to be in a low aerodynamic position.
garjo
by garjo
I should check the measures of these ones (even if IMO they are not so light cages), but that Ritchey model gave me an interesting idea to apply to my actual cage, an Hylix (9 grams)
The double holes idea like Arundel Mandible cage is interesting too..
Wookski
by Wookski
Carbonworks sit super low and are possibly the best looking cages available
garjo
by garjo
Wookski wrote:
Sat Jan 27, 2018 11:48 am
I have had one, but IMHO is definitely a best looking, light, functional, stiff cage but very fragile, having a hollow carbon structure.
NiFTY
by NiFTY
Your bike has a hollow carbon structure
taztaylortaz
by taztaylortaz
NiFTY wrote:
Sun Jan 28, 2018 9:23 pm
No.. my bike has a hollow aluminum structure. :wink:
