How much does chainring stiffness matter with Di2?
vinuneuro
by vinuneuro
I am looking at some 46/30 cranksets, but once you get to that gearing range the rings look pretty skinny (a lot less material) compared to normal ones and they are are direct mount so less support without a proper spider. I can't imagine the SL-K modular in the first pic as stiff as the the normal SL-K below. But does it matter with a Di2 front derailleur? Image
Sent from my SM-A320Y using Tapatalk
'16 Spec Diverge Expert
ooo
by ooo
With less material shifting will be slower. Shimano FD expects more ramps, like this:
BdaGhisallo
by BdaGhisallo
Shimano’s hollow chainrings arrived at the same time as DI2 did - DI2 exerts a lot of force when it shifts chainrings and the more stout chainrings are needed to better handle the force of the DI2 FD.
