Misaligned Carbon Frame?
billspreston
by billspreston
I hold this manufacturer in high regard with respect to quality so I feel Option 1 is likely. I realize that manufacturing is not 100% fault free so if a replacement is provided I will be happy.
wingguy
by wingguy
liam7020 wrote:
Thu Jan 18, 2018 8:12 pm
Could it be assymetric chainstays eg Pinarello F8
Outside of a really half-arsed knockoff design or the type of dropped drive side stay you don't see on pure road bikes, assymetrical chainstays shouldn't change the tyre clearance from one side to the other.
glepore
by glepore
Not unheard of. A respected manufacturer had this issue with some frames a few years back, and warrantied quite a few.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.8) ; Anvil Custom steel Etap;1996 Colnago Technos Record
pdlpsher1
by pdlpsher1
Because the wheel is so big, even the very slightest anomaly at the dropouts will cause the wheel to not be perfectly centered. This does not mean the frame is defective. Every frame that is made is never 100% perfect at the dropouts. So before the frame is shipped it’s checked for proper wheel alignment at the dropouts. Adjustments are made to bring the wheel back in alignment. This is done by either removing or adding more materials to the NDS dropout. Any frame builder can do this in less than two minutes. It’s not rocket science. If you are mechanically inclined and have a dremel, you can correct the problem to perfection in less than ten minutes.
Fast forward to the 6:30 mark in this video to see how this adjustment is done on every bike that is made.
https://m.youtube.com/watch?v=xJDea5mSUJY
billspreston
by billspreston
I think that is best left up to the manufacturer at this point. I believe in this case material would need to be added to the NDS dropout to bring things into alignment and I'm not sure how that would be done on a carbon dropout. I am not mechanically inclined when it comes to composites. Perhaps if I just had to file down a titanium dropout like the video I might give it a shot, but this is a $$$$ frameset so expectations for QC are higher than normal. IMO a frame at this level (or even 1/3 of this level) should not require modifications from the end user to align a tire width that is spec'd to fit (calipers to 28.0mm).
pdlpsher1
by pdlpsher1
If you have never done this yourself then yes, leave it to the manufacturer to fix it. It's not just about adding or removing materials. It's about adding or removing materials at the right places in the dropout. A very very slight change in material will cause a big change at the rim because the wheel is so big. So it takes an experienced operator to get it to align perfectly. Good luck and please report back the end result.
Valbrona
by Valbrona
pdlpsher1 wrote:
Sat Jan 20, 2018 2:53 am
If a wheel is 2/3mm off centre, why would the frame not be defective?
Never read so much shit written in a thread as this one.
Incidentally, for anyone trying to correct something like this themselves you can use a DT Swiss RWS twist-style skewer which gives much higher clamping force, thus allowing for a little re-alignment of the wheel. But use a different 'nut' on the end rather than the standard alloy one, like an old-style all-steel one.
pdlpsher1
by pdlpsher1
Valbrona wrote:
Sat Jan 20, 2018 10:14 am
A non-centered wheel doesn't mean the frame is out of alignment. The dropouts just need to be adjusted so the wheel can track straight. A drop out alignment and frame alignment are two different things. If you watch the linked video above, the frame is aligned first then the dropouts are adjusted as the last step. Carbon frames are produced with very accurate alignments to begin with. This is because each molded pieces are bonded together with good control of alignment. Metal frames can distort after welding and they are more prone to mis-alignments. But metal frames can be re-aligned quite easily. Carbon frames cannot.
ooo
by ooo
if chainstay length is the same on the left and right (distance from bb to dropout), than probably it is just dropout misalignment problem
wingguy
by wingguy
That’s crazy bad advice. Not only are you probably going to be left with a loose dropout regardless, you’re completely screwed if it doesn’t go right.
Take a new frame back to the shop with a misaligned dropout and the manufacturer will warranty it. Take a frame back to the shop with an obviously dremelled dropout and the manufacturer will tell you to get f**ked....
pdlpsher1
by pdlpsher1
Just because you don’t want to take this approach doesn’t mean my advice is bad. The decision to proceed should be left to the individual. My point is that this is not rocket science if you are mechanically inclined. And the materials removed is very little. You can’t really screw it up if you take your time and check your work.
wingguy
by wingguy
pdlpsher1 wrote:
Sat Jan 20, 2018 6:29 pm
It is definitely bad advice to tell someone with a genuine warranty issue to take action which would void that warranty and leave them up shit creek if it doesn't work or they do it wrong.
How many times have you personally done this?
Zakalwe
by Zakalwe
Shockingly bad sdvice
Calnago
by Calnago
Ouch!! It's a new frame... get it warrantied if they deem it a warranty issue and I can't see why they wouldn't. Also, you don't try to "align" carbon stays or dropouts. You could break the frame. Ti or steel is malleable and sure, you can twist and bend the dropouts to align them and there are proper tools for this (I have them, but never use them these days, since most stuff is carbon). And if you start resorting to filing and dremelling to make things square and even, you'd better have proper jigs and measuring devices to make sure it's done right. Plus, do you really know if the stays are correctly aligned in the first place, or if you've just corrected one wrong with another. The only filing I do on dropouts these days is just to possibly remove excess thick paint. Oh, and the lawyer tabs (shhhhhh).
pdlpsher1
by pdlpsher1
Ok. Bad advice it is. I'm just trying to help the Op and let him know that his frame is most likely OK but the dropouts needed some adjustments...
