Misaligned Carbon Frame?
billspreston
by billspreston
Hey all, I'm building up a very nice frameset here and have discovered a concerning issue. If you look at the photos below you can see the rear wheel is quite off center between the dropouts. I've included photos of two different wheels to illustrate that it is not wheel dish causing the misalignment.
  • I've put 3 different wheels in the frame with the same off center result.
  • I've reversed said wheels (cassette towards NDS) to verify wheel dish with the same off center result.
  • Wheel is also off center at the seat stays.
  • Removed and swapped derailleur hangers to make sure it's not the hanger.
  • I've checked for paint/clearcoat that might be interfering with the alignment and found no issues.
Based on this, I've concluded that the frame is misaligned and have stopped the build. Am I correct in this conclusion? If so, my understanding is that carbon does not bend or warp so the frame came this way from the factory and cannot be corrected. Therefore, I should be pushing for a replacement, yes? Thanks for any help and opinions as always!
Kumppa
by Kumppa
I had some problem with brand now wheel
which was offcentered couple 2mm. Test with other wheel.
Attermann
by Attermann
Kumppa wrote:
Thu Jan 18, 2018 6:03 pm
Read the text again
Mr.Gib
by Mr.Gib
Sounds like you have a thorough analysis. Reversing the wheel tells the story. Send the supplier a photo with the wheel in properly and another photo with the same wheel reversed and demand a refund/replacement.
Kumppa
by Kumppa
Attermann wrote:
Thu Jan 18, 2018 6:14 pm
Read the text again
My bad.
Zakalwe
by Zakalwe
Is there clearcoat overspray in the dropout, a tiny amount on one side would push the wheel out like that.
Never mind, just read properly now I’m home.
wedgie
by wedgie
Is the wheel aligned accurately between the seat stays? I had a similar issue with a carbon frame a few years ago. It was caused by a slightly misaligned derailleur hanger. A new hanger solved the problem.
wedgie
by wedgie
Just read your post again. Obviously not a hanger problem.
stormur
by stormur
With frames being "asymmetric" it's common look, however your doesn't like it is "asy"... You checked all properly, so conslusion also seems to be correct IMO.
ISO is very certain about tire clearance ( for given by manufacturer size ) : so as an argument you can use it doesn't fit to the "norm" - not enough clearance on 1 side. From experience... 2mm doesn't mean "difference" for some brands. It's still "fine" ... .
Mark Twain
liam7020
by liam7020
What frame is it? Could it be assymetric chainstays eg Pinarello F8
Tarmac SL6 & Campag Record EPS https://weightweenies.starbike.com/foru ... 0&t=153968
billspreston
by billspreston
AFAIK the frame has symmetrical chainstays. I'd prefer not to name the frame before I give the manufacturer an opportunity to fix it. I just want to be thorough and informed on the issue before speaking with them and make sure I'm not missing anything silly. It doesn't sound like that's the case, so now I will contact the manufacturer and see what they say. As it stands, I'm hopeful for a positive outcome and will keep the thread updated.
UpFromOne
by UpFromOne
Love a good bike mystery, and this sure is one!
You say you installed each wheel in both the proper and reverse positions, and that with both positions, the tire locates the exact same place, nearer to the DS chainstay as your pics show.
If that is true (which would prove equidistant dish of the wheel), then the next issue is whether the DS dropout is further from the frame's centerline than the NDS dropout. This is not necessarily the case, as the BB shell might be designed asymmetric. Which would explain why the chainstays are different distances from the frame centerline, and why the tire does not align to the very center of the BB shell. So might that be possible for this frame?
(Not claiming to have the answer, just asking a question.)
Also, can you install both wheels, and from behind the bike look along the rear tire, to see if it lines up with the front tire when the fork is straight ahead? Do that on both sides of the tire. That's another thing to check, assuming front & rear tires are the same.
gospastic
by gospastic
Is it also off center at the brake bridge?
billspreston
by billspreston
^ Yes it is also off center at the brake bridge.
Yesterday I spoke with the manufacturer who agreed the photos didn't look right. So the frame is now being sent to them for diagnosis and I will post here with a resolution.
Valbrona
by Valbrona
Option 1/ Manufacturer agrees that misalignment is not within agreed limits and supplies a replacement frame.
Option 2/ Manufacturer says 'you have to live with it because that is the best standard we can make our frames to'.
All it takes is slightly misaligned dropouts to get this effect.
