New Specialized Disc wheel Roval 007 disc.
Slack
by Slack
From website;
Making up about 50% of your total race time, the bike portion of a triathlon is where equipment choices can make the difference between first and fifth. And no other equipment choice will save you more time than a disc wheel. While traditionally-shaped disc wheels are faster than their spoked counterparts, the 007 disc turns conventional design on its head, creating the fastest wheel available.
Disc wheels often fall into two categories—a completely flat shape, with structure coming from carbon fibre and a honeycomb-foam filling, or a spoked wheel that's been faired with a carbon fibre cover. In our quest to break traditions, the 007 uses a single layer of 1k carbon fibre on each side of the wheel, and it all comes together at the brake track bridge. This kind of carbon fibre is rarely used in bicycle components due to its high manufacturing cost, but it offers a bevy of performance benefits. This coveted carbon is much lighter than other layups, like 3k and 12k, and it can only be laid by the most skilled of carbon fibre craftsmen. It's complicated, but the payout is worth it, as it delivers a supple ride and one of the lightest disc wheels available. And in the real world, this means that it'll spin-up quickly and reduce fatigue over the long haul.
Stiffness is often the “hot-topic” in the disc wheel world, but we think it’s an interesting conversation. It's long been thought that efficient power transfer and high stiffness are directly correlated, but through extensive field testing, we've determined that this isn't the case at all. In fact, our initial disc was so stiff that, under power, it wouldn't flex with the frame and this caused brake rub. This wrongly creates the perception of a flexy wheel, when really, the wheel is actually too stiff. In order to solve the brake rub problem, we first designed our optimal aero shape and then worked on our internal stiffness targets to fit within what we consider to be a desirable frame stiffness.
And while light overall weight was a development priority, our focus was aerodynamics. Through hours of Computational Fluid Dynamics (CFD) and testing in the Win Tunnel, we developed a new-to-category shape that's optimized to work with a tyre for on-bike airflow. What this translates to is an all-carbon disc wheel that, on the non-drive-side, has a shape that's as aerodynamic as our current understanding allows, and a drive-side shape that's as aerodynamic as the wheel-dish and derailleur clearance will allow for.
To save every possible watt, we've also added CeramicSpeed bearings and DT Swiss 240 hub internals into our hub. Each 007 Disc wheel is also 2Bliss-Ready out of the box and comes with a padded wheel bag, quick-release, tubeless valve, and SwissStop Black Prince brake pads.
Designed for the most uncompromising athletes in the world, with engineering to match, the 007 Disc is the world's most advanced disc wheel for your race against the clock.
Rim Type: Full carbon clincher, 2Bliss-Ready
Rim Material: Carbon
Braking Surface: Carbon Fibre
Brake Track Height: 12mm
Rim Depth: Solid Disc
Rim Width: 19mm internal, 27.3mm external (at brake track)
Rear Hub: Roval Disc, CeramicSpeed bearings, DT Swiss 240 internals, 11-speed
Assembly Method: Handmade
Extras: Roval padded wheel bag, Roval steel quick-release, Roval tubeless valve, SwissStop Black Prince brake pads
phm8147
by phm8147
007 disc?? When will it be released?
dcorn
by dcorn
Released probably the same time as the vaporware Tarmac Disc...
TurboKoo
by TurboKoo
Hopefully someone will hit them hard for using 007 as they are so hard on others using Roubaix etc.
Scott Foil
Shimano 9150
Shimano FCR-9100-P
Shimano C60 tubulars
