2016 Orange F-Si Build/Carbon Lefty 2.0 -
nelsontod
by nelsontod
Like the title says, I am building a orange 2016 F-Si with the Carbon Lefty 2.0
nelsontod
by nelsontod
is the Cannondale Lefty 2.0 Thick Flange Steerer 134mm preferred ?
nelsontod
by nelsontod
Can someone tell me what headset I am going to need and share a link?
thank you
nelsontod
by nelsontod
Thanks grover. I did finally figure it out at cannondale experts. com.
my steerer tube will be 110mm
I was wondering if I should go with an ceramic option for the top tube and bottom bracket bearings?
any ideas to save weight along the way? trying to save as much as possible right from the start
grover
by grover
if you want to save weight buy the MCFK or darimo carbon steerer. that allows a standard 1-1/8th stem. if you get a decent stem you end up 200grams lighter overall than the stock steerer and stem.
nelsontod
by nelsontod
good note grover i will look into that as well.
aspms
by aspms
Make sure you don't store that bike exposed in the sun, this Cannondale's orange paint work tends to fade really badly :(
cyrus33
by cyrus33
aspms wrote:Make sure you don't store that bike exposed in the sun, this Cannondale's orange paint work tends to fade really badly :(
Yes, I can confirm that...even with transparent frame protector
njleach
by njleach
How’s the build coming along?
