ceramicspeed bearing maintenance
Delorre
by Delorre
Guys, this weekend I removed the encaps + seals from my wheel bearings (roval clx 32 equiped with CS bearings). Especially the front don't spin well at all and feels a little gritty. The plan was to completely flush the bearings with brake cleaner and re-grease. Thing is, there seems to be a plastic 'cover' between the seals and the balls themselves. Those are not fully covered, so degreasing should not be a real problem, but re-greaseing seems a lot harder. Have you also already encountered such plastic cover? And it's only at the front. At the rear, the balls are exposed as usual. Front looks a little like the bearings on the left:
So completelty degrease or not? Or will the new grease find it's way without problem if used enough?
atakaoka
by atakaoka
Degrease and lube with light Oil.
cycling,a great individual sport,were you can't reach anything,whithout group effort.
Ironbarista
by Ironbarista
The cover you see is actually the ball retainer.
Delorre
by Delorre
atakaoka wrote:Degrease and lube with light Oil.
Maybe good for dry climates, but here in Europe, winters (and even the other seasons) are fairly wet, so I doubt that oil is the way to go. I don't want to this every few weeks...
kode54
by kode54
Ironbarista wrote:The cover you see is actually the ball retainer.
yup. use Ceramic Speed grease on the opposing side after cleaning.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
kavitator
by kavitator
Are you sure problem is in bearing itself and not with hub- bearing too tight in place (i have some wheels Roval with that problem)
Delorre
by Delorre
kavitator wrote:Are you sure problem is in bearing itself and not with hub- bearing too tight in place (i have some wheels Roval with that problem)
It could be, but that will be clear once the bearings are free of any grease and contimination. If still way too stiff and/or gritty, I'll ask the Spec concept store where I bought the wheels to have a look at it. The rear axle is also more smooth and free than the front :?
kavitator
by kavitator
Almost new and front bearing spin very hard (on stand with tire wheel spins around 20s than stop)
Delorre
by Delorre
kavitator wrote:Almost new and front bearing spin very hard (on stand with tire wheel spins around 20s than stop)
I get between 30 and 40 sec with front Roval (+/- 4000 miles), front Bora spins almost 10 minutes :shock:
kavitator
by kavitator
I they put CeramicSpeed in hubs then must spin like there is no friction
I think many front Rovals has this fault - but you notice only if you try rotate axle itself. With trough axle it is haredr than with standard quick release
If you dont know it doesnt hurt :mrgreen:
