9000 left arm on 9100 crankset??
Delorre
by Delorre
On the new 9100 equiped bike to be delivered, I would like to use my 'old' 9000 stages left crankarm. The look doesn't really match, but as temporarily setup, does it technically work? I guess so, as you could use a 105 stages arm on a 9000 crankset according to Stages.
Delorre
by Delorre
And instead of opening a new tread, I can ask here, as it's related : would you choose Stages again (I've been very, very pleased with it, in all regards) or go 4iiii. The latter is lighter, supposedly more accurate but only has 100 hours battery life vs 200 hours for Stages. @ 15 hours/week, this a not an un-important thing to keep in mind... Any user experience here with 4iii!?
steelbikerider
by steelbikerider
Yes, you can. I'm using a 7900 left arm on my 9000 crank. All 7800, 7900, 9000 and 9100 crank arms(not chainrings) are compatible. Ultegra and 105 are supposed to be but I have no personal experience.
MomentumR5
by MomentumR5
Can of BLK gloss paint and tape of the PM. BAM! Done.
Delorre
by Delorre
Would the use of heat shrink on the left arm have a effect on power readings? Using this woud a) protect the crank from shoe rubbing and b) give the crank a stealth look. But I'm afraid this will have a slight effect on the bending behiour of the crank, or am I too concerned?
eric01
by eric01
Too concerned. I doubt anyone would really notice
AX Lightness Vial Evo, Carl Strong Titanium
ms6073
by ms6073
Delorre wrote:Using this woud a) protect the crank from shoe rubbing
Might I suggest Crank Skins Black 3M Carbon Wrap, alternately, 3M colored protective tape?
oreoboreo
by oreoboreo
Thanks all... I was wondering the same thing as a upgrade is in the works
s
Let's finish the ride with a 20% grade.
2011 Scott Addict R1 DA 7900 Matt black
2012 Scott CR1 Pro Ultegra 6700
2015 Specialized SWorks Tarmac Da 9000
2016 Specialized SWorks Tarmac DA 9100
LouisN
by LouisN
I'm using a 9000 left arm with 4iiii Precision PM. I use it with the 9000 crankset on my road bike, and a 7800 crankset on my CX bike.
Absolutely no issues ( bought and installed last winter).
Changed the CR2032 battery once since, it took approx. 8 seconds to do so.
Louis :)
dmulligan
by dmulligan
I use a 5700 105 crank arm on my 6800 Ultegra crank. The look doesn't quite match but nobody has noticed yet and I've been riding this way for over 3 years.
D
Sent from my A0001 using Tapatalk
Philbar72
by Philbar72
al of the 5700 onwards and upwards are fine with all the others in the range... they do look a bit odd but hey ho...
