ETAP 1x
sholiday
by sholiday
I run eTap HRD 1x w/46 oval Absolute Black with xx1 10-42 with a WT roadlink. I did change the pulley wheels to larger ceramic 14T which helps take up some of the chain when in the 10T or 12T cogs. So far no chainslap or dropped chains.
Parlee Z3 4.94kg: viewtopic.php?f=10&t=101920
Wilier Cento Uno SL 5.52kg: viewtopic.php?f=10&t=101957
steelisreal79
by steelisreal79
sholiday wrote:I run eTap HRD 1x w/46 oval Absolute Black with xx1 10-42 with a WT roadlink. I did change the pulley wheels to larger ceramic 14T which helps take up some of the chain when in the 10T or 12T cogs. So far no chainslap or dropped chains.
Looking forward to seeing a picture of that setup, cheers!
kode54
by kode54
is that with regular short cage or wifli?
sholiday wrote:
Wed Jun 27, 2018 8:34 am
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
Jowwy
by Jowwy
kode54 wrote:
Mon Jul 09, 2018 8:41 pm
i got the same set-up using wifli
