10 Speed Cassette on Shamal Ultra 2015 wheelset. Do i need spacer or not?
3Pio
by 3Pio
Im preparing my winter bike (my old Pinarello FP3), and i will use my Shamals Ultra 2015 with Campy Freehub.
While beeing on my main bike i used 11sp 11-29 Chorus cassette, now i'll put 11-27 Centaur cassete 10 speed. Do i just put the 10 speed cassete or i need to install spacer first?
In the manual i can't find anything about spacer for Campagnolo Cassetes, but in my memory im almost sure that i removed some spacer when i switched to 11 speed.
Attermann
by Attermann
Campagnolo doesn’t use spacers, they are the same size across 9-10-11
3Pio
by 3Pio
Attermann wrote:Campagnolo doesn’t use spacers, they are the same size across 9-10-11
Thanks.
And i'll use the same thread for different topics.. I will have another rear wheel, also 10 speed cassette (Veloce 11-25). Should i use the same chain for this cassette that i will use for 12-27 10 speed, or to go with original chain (still not worn out), which is shorter?
Since i'll have KMC Quick link on both chain, it's not that big problem to swap when i swap rear wheel
