Focus Mares CX Tire clearance
Hello all,
Cross is coming ! And I'm on the lookout for a new bike. I'm reading good things about the Focus Mares CX and am just wondering about it's max tire clearance. So I can pop some wider gravel tires in come spring.
Would love to hear from you, also if you have any experiences good or bad with this bike.
- bearsdidit
- Shop Owner
- Contact:
I've fit up to 38MM with minimal rubbing.
I'm running 38c Schwalbe G-Ones on my Mares with no issues at all.
Wouldn't recommend going any bigger though.
I have 33c X-Ones for rainy days.
IG: RhinosWorkshop
IG: RhinosWorkshop
bearsdidit wrote:I've fit up to 38MM with minimal rubbing.
Any rubbing at all doesn’t inspire much confidence if you so much as pick up a pebble.
It's clearance by the BB that's the issue.
I would say that you could fit some 40s on 100% straight wheels and still have a few mm either side.
However, as soon as you pick up some mud, it's gunna clog up immediately.
Remember the Mares is a CX bike which should be used with 33c tyres (to legally race on). It's not a gravel bike that allows for huge width tyres.
IG: RhinosWorkshop
IG: RhinosWorkshop
Thanks for the replies ! Unfortunately the mares I wanted is sold out, which was a force 1 for the same price as a new apex1. So now I'm looking around for other CX bikes, with manufacturer clearance up to 40c. Since I don't (yet ) race any uci- events I would love to go wider than 33c, which all the newly released CX bikes will do.
- coloclimber
- Moderator
Im riding Schwalbe G-One Allround Evolution - TLEasy - Folding Tire - 40-622, 700 x 38C with wide Easton R90 SL Clincher Rim 19.5mm inner width and there is plenty of clearance. Wouldnt run 40mm with wide rims though.
-Deacon Doctor Colorado Slim
Don't think so, as the frame in the rear doesn't seem to be designed with 650 in mind ie curved and shaped chainstays. It will definitely fit 700x40 with about 3-4mm clearance on each side, but that's about it.
according to this article:yinzerniner wrote: ↑Fri Apr 27, 2018 11:27 pmDon't think so, as the frame in the rear doesn't seem to be designed with 650 in mind ie curved and shaped chainstays. It will definitely fit 700x40 with about 3-4mm clearance on each side, but that's about it.
http://www.bikeman.com/bikeman-blogs/65 ... -guidlines
to find the area of the stays and fork for clearance width, they say to measure 320mm from center of the axle. that's for 650b x 38mm tire.
how much would i add to 320 mm for a 47mm tire?
I recently picked up some zipp 30 course wheels (21mm internal) and was hoping to run the new specialized tracer in a 38c.
I tried out a 40c WTB nano, and it fits but is tighter than I would like. How much room is enough room? This would be a dry only wheelset so I’m not worried about mud clearance but don’t want to destroy a frame with a wheel wobble or by picking up a pebble.
