Caad9 rebuild
calv1n
by calv1n
Hi all, as a long time lurker and owner of 52mm caad9 for 9 years, I'm a big fan of the caad ww threads.
I'm having a crack myself and have just got an uncut enve 2 fork on the bay. It'll be replacing the premium, and I just wondered if anyone could advise on the headset - the current one seems fine and smooth - can I just take it off the old forks and put it on the new, or does the different rake angle (43 vs 45) prevent me from doing this?
Do I need special tools to remove / install headset?
Many thanks
Current set up, with dura ace c24s, which have deteriorated over the last 8 years, Original ultegra sl, Thompson stem and seatpost.
I'll be adding a 6800 groupset and ksyrium sls also.
Incidentally, will 6800 cranks fit on the pre BB30 bottom bracket spindles?
Thanks
Edit: I'm considering a new lick of paint as the frames looking a little worse for wear (though original scheme is nice) - any recommendations for powder coaters in London?
jobvisser
by jobvisser
calv1n wrote: can I just take it off the old forks and put it on the new, or does the different rake angle (43 vs 45) prevent me from doing this?
you should be fine, it will fit but it might change the handling a bit.
topflightpro
by topflightpro
I'm not sure what you mean by BB30 spindles, but Ultegra cranks have a built in spindle.
If you have a BB installed that already works with the 6600 crank in the picture, then yes, that BB will work with 6800 cranks.
