2018 S-Works Tarmac Disc
cnyn
by cnyn
So is there a Wahoo mount available which fits on the front of the bolts of the s-works stem?
Looking for such an mount because the standard wahoo mount is too thick and doesnt fit inbetween the s-works stem and the aerofly 2 bar.
cnyn
by cnyn
I am looking for something like this: https://enve.com/de/products/computer-mount/
But the gap between the bolts at the enve stem is probably bigger than at the sworks stem so this mount doesn't fit.
sychen
by sychen
I use the F3 form mount. Up to 41mm wide as the arms rotate and is flexible for different stem width.
No issues so far.
And yes it takes wahoo inserts.
tutle2020
by tutle2020
Anybody find any weights on the Tarmac Disc Sport and Expert stock builds?
Both look impressive for the price.
Slack
by Slack
cnyn wrote:
Thu Aug 23, 2018 6:33 am
I've used one of those on an S-Works stem, the bolt spacing is close enough.
alexneumuller
by alexneumuller
Finished build at 6.8kg. Second S-Works Tarmac I have had build up. Interestingly I find the changing gear system of Etap better than the DI2 on my other Tarmac, but the Shimano brakes feel superior.
IF Crown Jewel TI
IF Crown Jewel Steel
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
English Cycles 10th Anniv Edition
Cannondale SS Evo Disc
Torbjorn
by Torbjorn
Beautiful bike, of course, but I feel obliged to ask if you shouldn't have gone for a bigger frame size? That seat post..
alexneumuller
by alexneumuller
Yes, that thought had crossed my mind, however to ride a 58, and make the fit work I would have to ride a 90mm stem, and that is not happening as I don’t like riding short stems.
It’s quite an aggressive position with a drop of 168 I think, but am flexible enough and core strong enough to hold myself. Long legs and long arms as well. Longest Ride I have done on my other Tarmac which had same fit was 173km and felt fine, and most I have climbed on it one one go was 2800m and felt fine climbing.
My other Tarmac, same position, just need to swap seatpost to an in-line one.
Torbjorn wrote:Beautiful bike, of course, but I feel obliged to ask if you shouldn't have gone for a bigger frame size? That seat post..
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
jhalmar
by jhalmar
alexneumuller wrote:Finished build at 6.8kg. Second S-Works Tarmac I have had build up. Interestingly I find the changing gear system of Etap better than the DI2 on my other Tarmac, but the Shimano brakes feel superior.
Really nice bike! Care to share what components you did use (stem, handlebar, bottle cages, tires, saddle)? Thanks!
alexneumuller
by alexneumuller
Handlebar - Ax-Lightness
Stem - Enve Aero Stem 110mm
Bottle cages - Arundal Mandible
Tires - S-Works Turbo Cotton 26mm
Wheels - Roval CLX50
Saddle - Fabric Alm LTD
Bar tape - Supacaz Super Sticky
Garmin Mount - K-Edge Aero
Cassette - Sram 1190 11-28
Crank - THM SRM Powermeter 52/36
Speed play Steel Pedals
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
sharkotoo
by sharkotoo
Fri Aug 31, 2018 12:30 pm
Love your bike and i'm currently looking at the same - also in a 58cm. Can I please ask what your bike's measurement is from center of BB to top of seat, along seat tube?
Cheers,
Mark
alexneumuller
by alexneumuller
Just to confirm that it is a 56 Size wise. And measurement from BB to Saddle top along seat tube is 834mm
Cheers,
Mark
[/quote]
IF Crown Jewel TI
Open New UP
Stinner Ti
Speedvagen
Parlee Z-Zero Disc
Cielo Road Racer
Cervelo P5d
KevinM
by KevinM
Sun Sep 02, 2018 1:05 pm
Are you specifically asking him, or are you looking for generic measurements of the 58 Tarmac Disc? I ask because I have one if you need help.
sharkotoo
by sharkotoo
KevinM wrote:
Sun Sep 02, 2018 5:03 pm
Thanks for the reply. My seat height would be at 84.5cm... so about an inch higher than his. I wondered whether 1) I might be hitting the limit of the seat post extenstion and 2) whether it would look a bit strange.
Could I ask what your seat height is on the 58cm Tarmac Disc? Any chance of a photo?
Cheers
