What size ?
Nice! Did the Spidering just slot straight into the Ceramic Speed bearing cups?Mtbric wrote: ↑Fri Jul 19, 2019 8:06 pmJust found this discussion. Just built up a S-Works Tarmac SL6 disc that sits at 6.89kg with Hollowgram SISL (not SISL2) cranks, Power2Max power meter, pedals and cages. I'm not a huge fan of the murdered out look so I added some color with blue metallic vinyl. It can be removed at any time. The Hollowgram cranks was a cost saving feature because I came from Supersix Evo HiMod but works very nice. Pretty bad photo. I know.
S-Works
Dura Ace Di2, XTR 9100 rotors (I like the look)
CLX 32
S-Works Power Saddle
Cannondale Hollowgram w Power2Max Eco Power meter 52/36
3t Superergo LTD handlebar
Uno 7 debadged stem, black ti bolts
SRAM red 11-30 cassette
Speedplay Zero SS pedals
XTR RT-MT900 rotors*Mtbric wrote: ↑Fri Jul 19, 2019 8:06 pmJust found this discussion. Just built up a S-Works Tarmac SL6 disc that sits at 6.89kg with Hollowgram SISL (not SISL2) cranks, Power2Max power meter, pedals and cages. I'm not a huge fan of the murdered out look so I added some color with blue metallic vinyl. It can be removed at any time. The Hollowgram cranks was a cost saving feature because I came from Supersix Evo HiMod but works very nice. Pretty bad photo. I know.
S-Works
CLX 32
S-Works
CLX 32
Since a few people in the thread were wondering. I just took delivery of a 2019 9r Comp frame (56cm). Weighs 1930g in the same config as listed above, frame, fork, seatpost, headset, thru axles, threaded bb, rear hanger. So 200g more than the Pro.Jugi wrote: ↑Mon Jul 16, 2018 8:48 pmAny calculations? I ended up at 1737g for the 56 frameset, including headset bearings, seatpost clamping hardware and thru axles. Used components weights found with Google and plenty of educated quess work.
Can't be so heavy? I would have bet about 300-350g less.
Probably doesn't matter any more but yeah, acid mint paint job is definitely not adding 200gpedalbasher wrote: ↑Mon Mar 18, 2019 2:21 pmHmm. Shop scales (Park Tools) actually read higher, putting at almost 7.8 fully built. My own scales (also Park Tools) put it at 7.60.
Not sure what is going on.
Praxis conversion BB weighs c. 130g, forgot about that.
Wish I'd weighed the frameset first!
