HELP! Canyon Endurace AL: HOLE IN FRAME!
elephant
by elephant
What is this hole?
Need some help and I figure someone here has the answer. Please help me, please.
What is this? What do I do with it? What is the plastic widget with the zip tie on it?
The middle hole - not the braze-ons.
Thanks!
Hole
kkibbler
by kkibbler
Speed holes?
Serious answer: Di2 charge port.
shimmeD
by shimmeD
Bloody hell, it sounded like you were in crisis, with all that shouting and waving of arms :?
Less is more.
elephant
by elephant
kkibbler wrote:Speed holes?
Thanks!
So I leave it alone and if I ever run Di2 I will need that little plastic widget and the ziptie in there?
elephant
by elephant
shimmeD wrote:Bloody hell, it sounded like you were in crisis, with all that shouting and waving of arms :?
Of course! First road bike in 12 years and I cannot finish the build and test ride tonight until I know how to proceed. Everything else is ready to go for the first ride in the morning.
Panic all around!
saibot
by saibot
REAL ANSWER: You use the zip-tie to secure the rear brake hose in the down tube. (no brake hose rattling)
Broady
by Broady
saibot wrote:REAL ANSWER: You use the zip-tie to secure the rear brake hose in the down tube. (no brake hose rattling)
Yep, this is correct. First time I've seen it done but an interesting solution.
dj97223
by dj97223
It is the navel -- where the baby Canyon was attached to its Mommy.
elephant
by elephant
WIN!
Thanks!
ntb1001
by ntb1001
dj97223 wrote:It is the navel -- where the baby Canyon was attached to its Mommy.
Love this answer!!
Sent from my SM-G935W8 using Tapatalk
phlip
by phlip
What are going to put on the frame?
