Shimano 11-30 cassette with 9070 Di2
mnmasotto
by mnmasotto
Has anyone tried the new Dura Ace 9100 11-30 cassette with the prior Di2 9070 rear mechanical. Would really like to run 53/39 up front and a 11-30 cassette at the rear but do not want to spend the money to upgrade from 9070 to 9150. Any advice would be appreciated.
mai
by mai
i guess it depends on your frame/hanger geo. previously i have ran sram xg1190 11-30 with 6870 short cage rd on my tcr - no problem at all after a little b-screw adjustment.
mnmasotto
by mnmasotto
I have two bicycles. Colnago C59 size 48 sloping and a Tarmac S-Works size 52cm. Both have Shimano Dura Ace Di2 9070. I am currently running Dura Ace 9000 11-28 cassettes on each bike. Would like to swap to 11-30.
cunn1n9
by cunn1n9
Have a cervelo S5 and a Pinarello F8. Both with 9070. Both can fit 11-30 cassette. I know some people have fitted an 11-32 on but I think that is pushing the limits. Look at RoadLink too if you are having problems.
spdntrxi
by spdntrxi
I use the SRAM RED 11-30 with 9070 SS RD
Ritxis
by Ritxis
RD-9150 with 11-40 cassette.....Only tested on support
https://youtu.be/vW2MUUVvFOs
pdlpsher1
by pdlpsher1
Ritxis wrote:RD-9150 with 11-40 cassette.....Only tested on support
It looks like the chain was on the small ring. So what happens if he accidently shift to the big big combination :shock:
I have ran 11-34 with 9070 using a Wolftooth RoadLink. This is only a temporary solution when I need a 11-34 for special rides. But I made the chain longer so I don't accidently damage my derailleur or frame if I shift to the big big combination. But since the chain was too long, I cannot use the three smallest cogs when the chain is on the small ring.
MXGimp
by MXGimp
I tried this exact combination on my Blue Triad and it does not work. B limit screw all the way out and it still wasn't enough room. :(
