Single Speed with Brakes ready to buy????
alexneumuller
by alexneumuller
Looking for a Winterbike ... more specifically a Roadbike setup with drop handlebars that is singlespeed, has front and rear brake and is an aluminum or steel frame. Not something I need to piece together, so to say ready to purchase of built. Ideally something that can take 28mm tires at the very minimum!
Any recommendations?
Parlee Z-Zero Disc
Stinner Frameworks Ti
Speedvagen 2017
Colnago C64
Independent Fabrication Crown Jewel TI
Felt IAFRD
Cannondale Super Evo Six 2017
Opencycle O-1.0
Open New UP 2017
Canyon Inflite 9.0 2015
jekyll man
by jekyll man
Charge plug?
Official cafe stop tester
kdawg
by kdawg
Genesis Flyer? http://www.genesisbikes.co.uk/bikes/roa ... lyer/flyer
I've got a Day one disc I use when the weather is really filthy - similar but heavier with disc brakes. Been pleased with it.
I'm left handed, if that matters.
nemeseri
by nemeseri
Bianchi pista? Decent bike for $769.
I bought one of these used for $300, put better bars and brake levers on it and been happy with it for long time. Until I realized again that having gears is a pretty nice thing.
964Cup
by 964Cup
+1 for Bianchi Pista, but you will need to change the bars (steel, heavy and track shaped), levers (bartop) and probably freewheel unless you're massively strong - it comes with 48x16. I'm running some Cinelli Criterium bars, old 105 levers and a 48x17 fixed setup on mine.
Multebear
by Multebear
Wouldn't recommend a track specific frame. They limit your use to track wheels with track wheel specific freewheels like the white industries freewheel. There are a lot of crap freewheels on the market, and they wont last long. WI are some of the best ones, but they are expensive. And if you want to change from lets say a 16T to a 17T, you need to buy another one, and as said, they are expensive. Much better to buy a road frame and use road wheels with single speed conversion kit.
This way you'll easily be able to change to another cog, and you'll be able to use all kinds of road wheels, which you'll often find without braking the bank. Besides that, road hubs are usually more durable than freewheels, even the WI ones. If you choose the conversion solution, you'll need a chain tensioner os well.
This way you'll have a lot of frames/bikes to choose from. And if you're willing to buy second hand, the options are unlimited.
If you insist on the ready build single speed with option for big tires, then take a look at the On One Pompino. Cheap and a good bike. Lot's of options for fenders and racks as well. If you want it with discs, it's the On One Pompetamine you'll be looking for.
