Need pump for tubeless tires
eyedrop
by eyedrop
I've been riding road for 5 years and recently picked up a mountain bike to mess around on a few times a month. The tires are tubeless with sealant in them. I bought some sealant to top off and keep things fresh, but realized I need a special pump for popping the bead back on the wheel.
Ive been using a cheapo $25 Zefal Air Max Model# 5610 pump I purchased at Wal Mart 5 years ago when I started riding, and have had zero issues with it. Its kind of cheap and flexy feeling compared to my friends pumps. But honestly, the thing has been surprisingly reliable. I never understood the need to spend a bunch of money on a floor pump...
So what tubeless compatible floor pump do you recommend for best bang for the buck? It needs to service both MTB and Road tubeless, as I plan on experimenting with road tubeless in the future.
Also, I got to thinking.. Why not just buy an electric air compressor since its literally cheaper than buying a fancy floor pump, and it can serve many more purposes. What do you think?
justaute
by justaute
Depending on a number of variables...budget, noise, convenience, etc. There are several pretty good options based on what I've read -- Bontrager Flash Charger, Topeak Joe Blow, Lezyne, etc.
I use a Lezyne Overdrive (with digital gauge) and it works fine. It's not noisy like my old air compressor, but obviously more work and has limited utility. It is mobile and I get a good "workout" from all the pumping. It has certain value :) If I buy another house, I would likely have another compressor, albeit a quiet one.
Also, in case you are not as familiar with tubeless, if you are just topping-off the tire with more sealant, there's no need to break the bead seal. Just get one of those large syringes with attachment (e.g. Stan's, ebay) and do it through the stem/valve, assuming you have removable valves. I usually "dry" mount my tubeless tires (no sealant) and then inject the sealant through the valve -- same with topping off. An advantage to "dry" mount is you get an idea how well the tire is mounted and how long it will hold air. I do this with all my tubeless tires, road/gravel/cx/mtb.
My two pesos.
eyedrop
by eyedrop
Im using orange seal. The bottle came with a hose that you can attach to the valve stem after removing the core. Are you saying that if I totally deflate the tire and remove the valve core, the tire will not come off the bead?
bikewithnoname
by bikewithnoname
No special pump is needed, you can seat most tyres with a normal floor pump usually. However the pumps justaute mentioned do make it easier especially if you are running large volume tyres (2.5 and bigger)
I use a Joe blow sport yellow floor pump for road and my mtb (but haven't had to seat an mtb tyre in about a year to be honest)
Pegoretti Responsorium, Parlee Z5i, Donhou Commuter, 1946 MacLeans Featherweight L'Eroica!, 2x MTB 'dales
justaute
by justaute
Correct -- assuming you have tubeless "compatible" rims.
eyedrop wrote:Im using orange seal. The bottle came with a hose that you can attach to the valve stem after removing the core. Are you saying that if I totally deflate the tire and remove the valve core, the tire will not come off the bead?
kode54
by kode54
i take mine down to the gas station. i really only need to burp it...so its only on the initial install. i have too many pumps and stuff. cutting it down to only the Silca Pista.
one time, i was able to seal up the bead by putting in sealant, flipping it upside down and worked the sealant around the edges...then started pumping. worked a few times.
- Factor 02 Disc + DA9170 + Enve 4.5AR CK CL hubs
- Moots Vamoots Disc RSL Titanium + DA9170 + Enve 3.4AR CK CL hubs
- Parlee Altum + DA9150 + Enve SES 4.5 Ene carbon hubs
- Argonaut Spacebike 2.0 + DA9170 + Enve SES 5.6 DT Swiss 240 CL hubs
kulivontot
by kulivontot
I've had good success with the bontrager flash charger, aside from the pump head breaking. Which i then replaced with a lezyne thread on head
AJS914
by AJS914
I was able to install tubeless tires with just my ancient Silca track pump. I did have to over inflate them to get the bead to pop in place.
On one tire I taped it around the outside with masking tape to compress the tire towards the rim in order to get it to start to pump up.
FIJIGabe
by FIJIGabe
kulivontot wrote:I've had good success with the bontrager flash charger, aside from the pump head breaking. Which i then replaced with a lezyne thread on head
Good to know! I haven't had a problem with my FlashCharger, but I have had to replace the grommet in my SuperCharger (yes, I have both), and I believe they're out of production now, so I'm going to have to swap heads the next time the grommet fails me.
Regarding the original question, the only problem I have with the FlashCharger is that you cannot use it without the reservoir. It would be nice to be able to deactivate that portion and just use it as a pump, rather than having to fill the reservoir and the tire at the same time. That really keeps me from using it as my full-time pump. However, when setting up tubeless tires, it has never failed me!
Madone 9 - https://bit.ly/2Nqedbn
Emonda SLR - https://bit.ly/2UK5FP8
Crockett - https://bit.ly/2Xem4sk
Madone 5, Cobia. I own a lot of Treks.
kulivontot
by kulivontot
I don't really find the reservoir to be a downside. When you're starting from fully flat it gives you a head start and using the reservoir gives you better precision on the set pressure imo.
silvalis
by silvalis
Airshot.
Chasse patate
ddsg
by ddsg
I was also able to seat my tubeless tires with a standard pump (a road oriented pump at that). It took some furious pumping but it eventually worked.
jemima
by jemima
AJS914 wrote:I was able to install tubeless tires with just my ancient Silca track pump. I did have to over inflate them to get the bead to pop in place.
Kinda similar here with my mtb tyres, but use clothespegs: Inflate with tube; seat the two beads. Remove the tube, keeping one bead seated. Use a few clothespegs to lift the tyre / hold the opposite bead up close against the rim, sealing the tyre/rim gap fairly close. Pump up with normal road pump. Pegs pop off as the tyre inflates. Easy :D
Curve Grovel ti.
TheRookie
by TheRookie
Ghetto coke bottle accumulator works just fine for me.
Total cost was 2 old tubes and £1 for a piece of hose (plus £1 for the cola if you want to count that!)
