2018 Specialized Allez Sprint DSW LTD I: Updated
coriordan
by coriordan
Love the forks! Awesome work.
Front brake outer does look a little short and the one running down the RHS of the headtube looks a little odd, but these are easy fixes.
Normally I tend not to like very large frames, but this at a 61 looks absolutely amazing.
rossjm11
by rossjm11
the color of the cables is fine but the cable length looks sloppy
BMC SLR01 2015
Redline Conquest Team
IrrelevantD
by IrrelevantD
How'd you end up running the links for the brake cables through the top tube? I've heard that it wasn't possible. Did you use regular housing through the TT with links on either side? I have the Purple Chameleon and ended up doing a no-drill Di2 build. I contemplated getting links for the brake cables, but decided against it based on what I saw in the forums.
Tpb10505
by Tpb10505
Some updates:
S-Works Power Arc Saddle
Dura-Ace 9100 pedals
S-Works Carbon Crankset
Quarq DZero for Specialized
Zipp Sprint SL Stem 90mm
Some of the cable housing needs to be shortened since dropping them stack 1cm, but I haven’t gotten around to that yet. Comes in at 7.7kg. Thinking about some Roval 50s in the future to lose some weight.
Tpb10505
by Tpb10505
IrrelevantD wrote:How'd you end up running the links for the brake cables through the top tube? I've heard that it wasn't possible. Did you use regular housing through the TT with links on either side? I have the Purple Chameleon and ended up doing a no-drill Di2 build. I contemplated getting links for the brake cables, but decided against it based on what I saw in the forums.
I didn’t. I ran regular housing internally and links before and after. A little extra work but not terrible
sun
by sun
How do you like the Power Arc saddle? Do you happen to have any comparisons to the normal Power?
Tpb10505
by Tpb10505
sun wrote:How do you like the Power Arc saddle? Do you happen to have any comparisons to the normal Power?
I really like it. I started with a regular Power a year or two ago, but it was too flat for my liking. I then went to a Fizik Aliante, and preferred the shape more, but missed the cut out. The Arc is the perfect combo between shape and the cutout.
phm8147
by phm8147
Wow... 61size.
Cool!
ahhhlawn
by ahhhlawn
Bottom Bracket specs?
Also, how do you like the s-works crank arm/setup vs the DuraAce?
Klaster_1
by Klaster_1
Tpb10505 wrote:
Sun Aug 13, 2017 5:11 pm
Front Derailleur Dura Ace 9000
Shifters Dura Ace 9100
How's the front shifting? I thought that front ST-R9100 was compatible with FD-R9100 only, but you use it with FD-9000.
IrrelevantD
by IrrelevantD
ahhhlawn wrote:
Fri Mar 09, 2018 5:31 pm
It's basically BB30. Specialized still calls it OSBB, but anything with the aluminum sleve in it is fully BB30 compatible.
07stuntin6r
by 07stuntin6r
Awesome got a used sworks arc coming i got for $125 Image. See if I like it more than my power expert.
Sent from my SM-N950U using Tapatalk
