2003 Scott AFD Team — singlespeed on a budget — 5.60kg
Konsta
by Konsta
April 2018:
Some small spring updates.
Current spec list:
Frame: 2003 Scott AFD (994g) Image
Fork: Easton EC90 SLX (286g)
Headset: Tune Bobo (78g) Image
Expander: J&L (7g)
Top cap + bolt: Aerozine (7g)
Spacer: noname (1g)
Stem: Syntace F99, 26.0/90mm, tuned with ti bolts (94g)
Handlebar: ITM Kero3, 440mm (268g)
Handlebar tape + end plugs: Force (33g)
Brake levers: Campagnolo Record (211g) Image
Brakes: Planet X Ultralight CNC (185g)
Brake pads: KoolStop Salmon (20g)
Brake cables: Clarck's + Shimano (?g)
Brake cable housing: Jagwire Ripcord (47g)
Saddle: Selle Italia Flite Alpes (212g) Image
Seatpost: Thomson Elite 31.6/250mm with carbon cradle, ti bolts and lighter yokes (137g)
Seatpost clamp: Mortop 34.9mm, with a 0.3mm brass shim (13g)
Bottom bracket: Stronglight Twister (181g) Image
Crankset + crank bolts: Stronglight Pulsion, 172,5mm (347g)
Pedals: NC-17 Trekking with VP cages (256g)
Chainring: Stronglight 7075, 42T (67g)
Chainring bolts: noname (7g)
Chain: KMC X10SL (206g)
Singlespeed kit + lock ring: noname (27g)
Rear cog: Point, 16T (35g)
Wheels: noname hubs, noname aero spokes, alloy and brass nipples, Kinlin XR-200 rims (1 309g)Image
Rim tape: Schwalbe (11g)
Skewers: J&L (29g)
Tyres: Grand Bois Cerf Blue with EL casing, 26-622 (211+183g) Image
Tubes: Specialized Turbo Tube + Continental Supersonic (65+53g)
Total weight: ~5.60kg
July 2017:
Hi everyone. Been a long time lurker here. Since 2006 I think.
This is my singlespeed bike for road riding (not racing). It's built around a 2003 Scott AFD frame using parts I have collected over a long period of time.
I remember wanting this frame for a few years but in 2016 I finally found one from France and fortunately for a very reasonable price. The frame is somewhat different from Team Issues that I've seen: seat angle is surprisigly slack at 72° (needs a 0mm setback seatpost) and the rear brake cable housing stops are on top of the top tube. Also there is a small welded tab under the top tube to fasten race number to. I believe this could be the actual frame Gilles Bouvard rode when in Jean Delatour.
The build has gone through different incarnations of which this one with flat pedals (!) is the latest and most relaxed. The bike was almost 200 grams lighter with a Chinese full carbon saddle and my Look Kéo Blade 2 Carbon ti pedals but I have to admit my behind is somewhat used to those old school Flites. And the flat pedals make the bike very easy to just grab and ride: yesterday we went swimming — 50 kilometers in sneakers and a white collar shirt. So works great for non-performace types of rides like this.
Frame: 2003 Scott AFD (994g) Fork: Easton EC90 SLX (286g) Headset: Tune Bobo (78g) Expander: J&L (7g) Top cap + bolt: Syntace Litecap (8g) Spacer: noname (1g) Stem: Syntace F99, 26.0/90mm, tuned with ti bolts (94g) Handlebar: ITM Kero3, 440mm (268g) Handlebar tape + end plugs: Force (33g) Brake levers: Campagnolo Record (211g) Brakes: Planet X Ultralight CNC (185g) Brake pads: KoolStop Salmon (20g) Brake cables: Clarck's + Shimano (?g) Brake cable housing:[/b] Jagwire Ripcord (47g) Saddle: Selle Italia Flite Alpes (212g) Seatpost: noname 31.6/250mm, tuned with ti bolts and lighter yokes (120g) Seatpost clamp: Mortop 34.9mm, with a 0.3mm brass shim (13g) Bottom bracket: Stronglight Twister (181g) Crankset + crank bolts: Stronglight Pulsion, 172,5mm (347g) Pedals: Xpedo Spry (256g) Chainring: Stronglight, 44T (?g) Chainring bolts: noname (7g) Chain: KMC X10SL (?g) Singlespeed kit + lock ring: noname (27g) Rear cog: Point, 17T (36g) Chain tensioner: Surly Singleator, tuned a bit (98g) Wheels: Novatec and noname hubs, Pillar aero spokes, alloy nipples, Kinlin XR-200 rims (1 339g) Rim tape: Schwalbe (11g) Skewers: J&L (29g) Tyres: Grand Bois Cerf Blue with EL casing, 26-622 (211+183g) Tubes: Specialized Turbo Tube + Continental Supersonic (65+53g) Total weight: ~5.70kg
That's it. Not very much money was spent on this (from memory 750–800 euros all in, my laptop broke so I don't have the exact figures anymore) but I'm satisfied with the end result. The weight is good, it rides very nice and I don't think it looks that bad either.
So I like it, hope you like it too. Thanks for watching.
evan326
by evan326
I like it! :thumbup:
Konsta
by Konsta
Updated build in the first post.
euph
by euph
Great bike and weight. I enjoy seeing a lightweight singlespeed that actually gets used.
mcfarton
by mcfarton
Nice looking ride! Did I miss the gear inches?
Konsta
by Konsta
Thanks for the kind words!
But hmm... gear inches... 42/16 so Sheldons calculator says 69.2.
craciunptr
by craciunptr
Awesome bike :) very good weight too@ love the polished look of the stem.
Have you looked into aest titanium spindle platform pedals ? You should be able to save at least 80g
