New sram pf30 design
NiFTY
by NiFTY
Anybody used a new sram pf30 bb where the bearing shields actually continue into the inside of the bearing race to sit between the spindle and inner bearing race? I have checked and it doesn't change the diameter, it still accepts a 30mm spindle easily. Just haven't seen this before.
MayhemSWE
by MayhemSWE
New version also has much more overlap on the center sleeve, so that it can extend to cover the wider length of a 386EVO shell. Installed one on a friend's new Open UP earlier this week along with a Force 1 crankset.
grover
by grover
I've got really positive outcomes with them. The plastic sleeve extending between bearing and spindle seems to stop the creaking you'd often get. Having the plastic shell helps too. Many of our Cannondale's come with FSA PF30 bottom brackets. Alloy shell, steel bearing races that contact directly with alloy spindle. Often installed with minimal grease at the factory. Seeing as I have to pull them out to install properly I just replace with a SRAM one and get silent use for ages until the bearings themselves are worn out.
uraqt
by uraqt
Link, pix?
Please and thank you ..
C
