Canyon Stem
chunboon
by chunboon
Anyone knows how to change the stem off a canyon bike?
MayhemSWE
by MayhemSWE
Assuming yours came with an Acros i-Lock style headset the only difference is how you tighten it. Use a super tiny Torx key (should be a T8 or perhaps even T6) in the hole on the side to put the collar in its lowest position, push the stem down as best you can and torque it down to spec, then use the Torx key again to raise the collar until any play is removed. All done.
