why is the Di2 EW-RS910 bar end junction box not more widely adopted by pros?
ph
by ph
Not a Di2 user myself but wondering why the EW-RS910 Di2 junction box isn't more widely adopted by the sponsored teams (not on TdF17 bikes of BMC, DD, Bora, QS, etc)? Seems like it would be cleaner, touch more aero perhaps?
*edited for correct part no.
jobvisser
by jobvisser
ph wrote:Not a Di2 user myself but wondering why the EW-WU111 Di2 junction box isn't more widely adopted by the sponsored teams (not on TdF17 bikes of BMC, DD, Bora, QS, etc)? Seems like it would be cleaner, touch more aero perhaps?
think they will receive it later and if they are not given the new Junction box i don't think they will buy it as it is pretty expensive and unneeded
DeeHubbs
by DeeHubbs
There are not that many bars that are spec'd with cable holes for the EW-RS910. For how often they refresh tape, and even replace bars once they go down, it is simpler for them to run a traditional A-Junction under the stem.
itsacarr
by itsacarr
Several teams also have updated frames with down tube ports to mount the new junction in.
Otherwise, like Dee mentioned not many have ported handlebars. BMC is connecting the hoods externally if you look closely as well on the 3T models without cable ports. Hard to see but the wire runs just behind the SRM head unit.
Broady
by Broady
Barely any decent bars work with it.
djwalker
by djwalker
Just a note- the bar end junction is the EW-RS910. The EW-WU111 is the Ant+/Bluetooth communications device.
ipenguinking
by ipenguinking
My LBS was able to install EW-RS910 in my 3T Ernova cleanly with e-tube and brake cables running inside of the bar before coming out from bar's holes on the bottom. I know Richie Porte is also running the same bar so in theory EW-RS910 should work nicely for him except his new BMC Teammachine frame has a dedicate location for the junction box (like F10) which might be an even better solution.
moyboy
by moyboy
I think they use the external as it's easy to replace and debug no?
wheelbuilder
by wheelbuilder
moyboy wrote: ↑
Tue Apr 17, 2018 12:42 am
This. I worked for a UCI women's team service course very briefly and the sole reason is for ease of use. Much easier to switch from bike-to-bike, much easier to check connections, etc.
wheelbuilder
by wheelbuilder
Moyboy is correct. I worked for a UCI women's team service course briefly and it is for ease of use. Easier to switch from bike to bike, easier to double check connections.
