Chapter2 Tere
cwdzoot
by cwdzoot
Monkeyfudger wrote:
Fri Jan 19, 2018 10:17 am
Check your stem length... I never planned on using mine but got a120mm I thought would be useful on another bike, I came to use it the other day and awesomely despite being labelled as a 120mm it measures 110mm.
Would be very unusual for a stem to be labeled 120 but actually be 110. Has to be the way it was measured. It's easy to get it wrong when you hold a tape measure up against the side of the stem.
Instagram - stylish square bike pics
Flickr - over 20 million views for good reason
Facebook - friends get the good info & coupons first
Monkeyfudger
by Monkeyfudger
Thanks...I didn’t actually consider I might have measured it wrong so definitely didn’t directly compare it to another couple of stems...
silvalis
by silvalis
How did you measure it?
My 110 stem measure 110 C-C
Chasse patate
Djkinsella89
by Djkinsella89
Some stems are inaccurately made/measured by certain companies, typically these discrepancies are well within 10mm from everything I’ve seen. And then some stems are just measured in odd ways by the manufacture, like Nitto measuring their stems 90degrees from the steer tube axis resulting in actual stem lengths ~7mm longer than marked.
Monkeyfudger
by Monkeyfudger
Longest build ever, almost looks like a race bike now.
7.2kg as pictured, 1kg less than my previous race bike which isn’t to be sniffed at when you only weigh 61kg!! Defo not Weenie Worthy but not bad considering Clinchers (tubeless) and a power meter.
ipaul
by ipaul
That came out great. So worth the time you put in it. Congrats, enjoy and a bit envious :wink:
:P
SimmyD
by SimmyD
Bike complete and working great!
SimmyD
by SimmyD
I do have extremely small clearance between my rear tyre and the SRAM red brake. Any tips on a getting some more clearance without going from 25mm to 23mm?
cwdzoot
by cwdzoot
The rear brake clearance would not be an issue with the new Ultegra caliper but that might look weird on a SRAM Red bike. I run 28mm Vittoria on zipp Firecrest with the Ultegra.
Another option eebrake. Expensive but they work great and have huge clearance.
Also helps a little but not a ton to add a 2mm washer between caliper and brake bridge.
or file a few mm off the underside of the metal washer of the brake.
SimmyD
by SimmyD
So update on my Tere,
Dopped to 23mm Pirelli tyres which measure up to 26mm with my rims.
Had a creak under load which I couldn't find. Worried it was my BB that I put in.
Ended up taking it to a shop and they narrowed it down to the rear wheel! it was a bearing that needed replacing in the hub! would have never found that myself :P
Running super smooth now. Such a lovely bike!
silvalis
by silvalis
:D
Chasse patate
SimmyD
by SimmyD
Been a week now of smooth riding.
This bike just feels nimble and fast under me. 🤘 Time to start hitting the crits.
moonoi
by moonoi
Decided to update mine a bit, Campag SR has gone and replaced with etap, brake clearance for wider tyres is terrible though, had to downsize from 28mm Turbo Cottons to 24mm S-Works Turbo to get adequate clearance at the rear...might look at eebrakes when I've got some spare cash and maybe the new Chapter2 Mana integrated bars
Sent from my SM-G965F using Tapatalk
Monkeyfudger
by Monkeyfudger
Has anyone modified their seat post yet, I’m amazed at how they managed to choose such a shit design that weighs so damn much!
silvalis
by silvalis
Whats wrong with it? Weight isn't really any different to my 31.6 Superlogic 1bolt.
I trimmed mine and added a Ti bolt for 136.6g. Saved a whole 6g with the Ti bolt.
Chasse patate
