Scott Foil - Syncros RR1.0 Handlebars
p3dalfaster
by p3dalfaster
Folks,
I thought I'd post this for any Scott Foil owners who have the intergrated handelbars. My Foil came with the 420/110mm version, but I found the 110mm stem measuring closer to 120mm. The original handlebars are no longer made, so what turned up caused 1 or 2 issues, mostly 1) The Di2 junction box is no longer under the stem, it's now in the bar end, 2) Due to the first point, the Garmin mount has now changed. Anyway, the Di2 junction box is now the bar end version Di2 EW-RS910, and I also needed a brand new Garmin moint. This time I ordered the 400/100mm version and they fit abolsutly perfectly. I've posted a pic below of the new cockpit. If anyone has any questions, please let me know.
Cheers :)
ab01ns
by ab01ns
I work at a Scott dealer and we discovered the mount and bar changed for 2017 when I went to install the 2016 style Garmin mount on a 2017 bar and it didn't work. Sigh. Definitely frustrating, but not the end of the world
Sent from my Pixel XL using Tapatalk
20% cyclist/80% J.I.T
dlcrep
by dlcrep
I have the original RR1.0 computer mount and an aftermarket one that runs Pioneer/GoPro combo if you guys are interested.
p3dalfaster, good catch! I'm running the 420/110 and noticed something was a bit off. The 400 is just too narrow for me. Btw, is your stem top cap flipped in the first photo?
p3dalfaster
by p3dalfaster
You're welcome, I found it odd myself, to say it's only 10mm, it's super noticeable! It was indeed the wrong way around, I almost always make that mistake :roll: :lol:
yourdh
by yourdh
dlcrep wrote:I have the original RR1.0 computer mount and an aftermarket one that runs Pioneer/GoPro combo if you guys are interested.
p3dalfaster, good catch! I'm running the 420/110 and noticed something was a bit off. It said that it is of the first kind, but I was not sure if I was looking at the right thing. It doesn't look right. The 400 is just too narrow for me. Btw, is your stem top cap flipped in the first photo?
in your opinion, which one is better, the original or the aftermarket?
shinjiwoon
by shinjiwoon
Other stories,
Your bike is really cool.
Pokerface07
by Pokerface07
I couldn't feed DI2 cables through the bends on my RR1.0 bars. One of a few reasons I changed them to something else. Maybe they fixed the problem with the 2017 bars...
Did you have any problems?
Twitter: @FormerTTchamp https://twitter.com/FormerTTchamp
Indyx
by Indyx
I found the same problem in length!
When you measure the center line of the stem bolt to the end of the handlebar and subtract the average handelbar width/2, you get somewhere in the neighborhood of stem length at 118mm for a "100 mm" Stem.
So you bought the 2017 handlebar and somehow moved your Di2 charging box to the handlebar, and changed the garmin mount?
That is exactly what I would like to do! Go to the 100mm/420 handlebar and move the di2 box to the handelbar end.
How hard was it?
Damian75
by Damian75
ab01ns wrote:
Wed Jun 28, 2017 3:08 pm
Does the new bar use the standard splayd mount like the one from K-dege, the only one I saw from scott was for a garmin and I run a wahoo.
dlcrep
by dlcrep
yourdh wrote:
Fri Jun 30, 2017 11:39 pm
The original is definitely cleaner but if you need a combo mount for a GoPro/light attachment, Rec-Mounts is your only choice. I did like that the computer sat slightly closer with the Rec mount. If you have access to tooling, you can probably add a K-edge adapter beneath the OE mount.
