52/34 Gear Combination
Hi WW,
The bike that I would like to try this combination on it has an 11-28t cassette, Ultegra short cage derailleur, 52/36 chainrings.
For special occasions, I was wondering if for special occasions I can switch my 105 long cage (maybe medium?) derailleur and 11-32 cassette off another bike and buy a 34t chainring resulting in an end combination of 52/34 and 11-32t.
Would this work? I do understand that there is a theoretical 16t gap in the Ultegra front deraileur.
Thanks
Thanks
A standard crank has as you know 53/39 = 14t size difference. Advantage is smooth shifting between the chainrings.
A compact has 50/34 = 16t difference and is comparatively a little bit more trouble to shift smoothly.
You wish to try 52/34 = 18t difference.
If you don't mind the shifts to potentially be a bit troublesome then I think you can do it.
Certainly I don't think anyone would race on something like that and most riders wouldnt want to deal with the tricky shifting/noise/dropped chains it would potentially introduce. But if not for racing then I say why not..
/a
/a
Fwiw, I ran 52-34 on 7870 DA (using a 9000 crank) for a couple years with no shifting issues nor any chain drops (or at least none that I remember). I'd still run it if it were offered on Cannondale spiderings.
Cysco Ti custom Campy SR mechanical (6.9);Berk custom (5.6); Serotta Ottrott(6.
; Anvil Custom steel Etap;1996 Colnago Technos Record
I have seen it done too..
I've done it, and it shift well.
Praxis 52 outer and Sram 34t inner with Shimano Dura-ace Front derailleur and Sram Red22 Left shifter.
I can make this combo with very well, on 11-28 cassette.
34 can be use with 28-16 without chain rub. 15t is usable but occasionally rub. 14t and smaller get consistence rubbing. This limitation come from Sram's shifter has no Trim and Dura-ace Shifter has no Yaw. Not from 52-34 itself.
52 can be use with all of them. No rubbing.
I stop doing it as i don't find i need 52 at all right now.High cadence and 50-11 is enough for me currently. I might change my mind if i ever think i need extra 4% harder gear up top.
Agreed, you only need 50 if you have steeper hills you need to bomb down.
I converted 2 bikes to a 46 big ring now which is plenty fast at the top end but lets me avoid the shift to the small ring for longer.
Note that 46/11 is faster than 53/13 which was the longest gear available for Merckx, and I am not faster than he was...
I got this chainring combo, it works well with no shifting issue and with a 11/29 cassette it gives a lot of useful gears for several different conditions, from 52/11 for fast descents to 34/29 for >18% climbs
My 4,93 kg Supersix Evo HM: viewtopic.php?f=10&t=137647&start=30
My 6,22 kg Cannondale R500 1996: viewtopic.php?f=10&t=134364
I've FSA 52x34 combination. Works perfect with 12x28 and 12x27 cassettes.
I've been running 52/34 on Campy SR EPS since the new cranks came out...almost 2yrs now. Shifting is seamless, no dropped chain/noise. That's w/11/25 but cassette ratio shouldn't make any diff. Thx
JScycle wrote:Hi WW,
Thanks
TA
sib wrote:Marin wrote:I converted 2 bikes to a 46 big ring
Does that mean you're running 46-34 at the front?
Which groupset is that on?
I also rarely use the 50 and would like to have a more useful big ring.
This is on a Sram Red group, but I also ran a Shimano Ultegra 6800 with a 46 big ring previously.
I'm using a TA Syrius 46t 11s ring currently, and shifting is great.
