Trek Madone 5.5 SL Project - Lance on Campagnolo
campagowlo
by campagowlo
I have been looking for a used Trek Madone from 2004-7 as the basis of a weenie build with Campagnolo. I always liked the US Postal Builds with the Newton Stems and downtube levers for the front mech and will build something similar but with Campagnolo.
I have been inspired by Daddy Yo Yo's build and will try something similar on a budget. I have finally found the frame and forks and will post pictures when I pick up the frame and forks on Saturday. It is currently in the grey with white and red decals with a Bontrager XXX-Lite Fork (non-stock).
I have sanded all the paint off the frame and forks and had it refinished with a satin clearcoat.
Anyway here is the build with weights:
sanded and refinished frame - 1089 grams
sanded and refinished fork inc starnut - 360 grams
Chris King Headset - 80 grams
Bontrager XXX-Lite Tubulars (stealth look no stickers) - 1260 grams
Veloflex Carbon Tubulars 260x2 = 520 grams
KCNC Titanium Skewers - 45 grams
Selcof debadged -10 Deg 110mm stem - 132 grams
Deda Traforato tape black - 29 grams
WR Compositi Shallow Carbon bars debadged - 253 grams
Fibrelyte Top Cap - 9 grams (inc bolt).
Smud Seatpost/ Saddle - 168 grams
Smud seat tube collar - 9 grams (inc bolt).
Campagnolo Record 10 Speed Right hand lever with schmolke carbon band - 162 grams
Campagnolo Record 10 Speed left hand modified to brake lever with schmolke band - 116 grams
Campagnolo Downtube Lever for front mech - 19 grams
Campagnolo Super Record RS Front Mech -69 grams
Campagnolo Super Record rear derailleur - 168 grams
Ciamillo front brake - 89 grams
Ciamillo rear brake - 93 grams
Recon 11-27 10 speed cassette - 114 grams (inc lockring)
PYC SP1101 11Sp Chain 211 grams
Campagnolo Overtorque Comp One Chainset 50-34
- driveside crank inc chainring and bolts - 428 grams
- non driveside crank - 167 grams
Campagnolo Overtorque BSA Cups - 99 grams
Look Keo Ti Pedals - 188 grams
deda traforato tape and bar end plugs - 29 grams
Tune Wassertrager bottle cage and nylon bolts - 8 grams
OEM downtube cable guide - 10 grams
Alligator ilink outer casings and inner cable housing - 45 grams
KCNC Gear cables trimmed - 24 grams
Jagwire brake cables - 36 grams
campagowlo
by campagowlo
Does anyone know what the o.d. measurement of the seattube is? My smud 31.8mm isn't big enough...
FIJIGabe
by FIJIGabe
Emonda SLR https://bit.ly/2UK5FP8
Crockett, Madone 5, Cobia. I own a lot of Treks.
campagowlo
by campagowlo
Thanks - that manual is ace. Its the 35mm seatpost collar measurement I was looking for...
brahl
by brahl
Yeah, it's 34.9 mm.
2006 Trek Madone SL 5.9
2016 Specialized S-Works Tarmac
2017 Specialized Allez DSW SL Sprint
Timo
by Timo
Subscribed!
And if I ever meet an aardvark, I'm going to step on its damn protruding nasal implement until it couldn't suck up an insect if its life depended on it.
SuperflyRick
by SuperflyRick
Waiting for some pictures
campagowlo
by campagowlo
Bontrager XXX Lite fork. This is non proprietary to the frame. I am surprised by the pleasing weight at 368 grans with the star nut installed and the fact it is an alloy steerer. They look sharp though, I like straight forks.
campagowlo
by campagowlo
A few bits for the frame. No brand spacer at 10 grams (will swap out for a deda spacer when it arrives just like Armstrong's bikes). Down tube cable guide.
campagowlo
by campagowlo
OEM Left hand side brake lever. I have looked for a while for a Campagnolo Record Brake Lever like Timo's. The only pair I have seen were too expensive for the build, but I will continue to look. This one weighs 114 grams which isn't too bad. It looks ok too. It's part of the early 2000s Grand Tour mountain stage look that I am going for with this build. My Campagnolo Record left ergopower shifter weighs 169 grams and the Dura Ace down tube lever weighs 32 grams. Therefore, not including the extra ilink housing this saves 23 grams.
campagowlo
by campagowlo
Madone 5.5 SL frame. I got a great deal on this, it needs a respray at the end of the season and the headset needs a bloody good polish (Chris King NoThreadset in silver). This frame is a 58cm and weight 1148 including the Chris King Headset (without crown race). I am pleased with this. Eventually I will either get it resprayed in gloss black with pink decals, or the reverse. Would appreciate some thoughts on this. I will go for a giro pastel pink rather than a dark or fluoro pink.
campagowlo
by campagowlo
Fibrelye top cap and screw 9 gm. One of the signature parts of this build is the Deda Elementi Newton 26.0mm Stem. This is the 2003 model onwards with the red logos. Deda weights are always unreliable, this 120mm weighs 149 gm not the 130 advertised. Still I love the looks and Armstrong always used one from 2001-2004.
campagowlo
by campagowlo
Smud saddle 68 gm and seatpost 100 gm. I find this combo comfortable with a decent pad in my bibs. I think it looks great on this build too! For the moment I will use the crap looking bontrager seat collar that came with the frame. I have ordered a 34.9mm smud one and will wait (Piotr is never speedy but I love his products!)
campagowlo
by campagowlo
For the moment I have fittted this Campaganolo Centaur Rear Derailleur that I have modified with a Tiso alloy bolt, fibrelyte rear cage and fibrelyte jockey wheels. When I have a bit more cash spare I will buy a Campagnolo Super Record RS rear derailleur, as it would save 36 grams.
campagowlo
by campagowlo
Campagnolo Super Record RS front derailleur 69 grams. However, I am struggling to get it to work with the downtube lever. I have never set up a downtube lever before and I am struggling to get the front derailleur to move out enough to get the chain to climb onto the large chainring. I have messed around with the outer limit screw and it still doesn't quite get the chain on, would appreciate some ideas here.....
