Addict project: sub 5k?
thePrince
by thePrince
My current 2011 Addict R1 is one of the "stolen from factory after it didn't pass QA" out there with the messed up rear triangle (and a pretty porky frame weight for a 56). Rear wheel runs to the left and will rub the stays with anything larger than a 23 tire. For my 30th bday present, I decided to try another Addict build with a proper rear triangle with a short-term goal of sub 5k, on a "budget".
I found another 2011 R1 frame, same paint scheme and all, and took a flyer on it. No issues with the rear triangle, and pretty happy with the weight...880 including the shimano press fit BB. So guessing about 815.
This will be my 3rd Addict, and the builds are getting a little formulaic, so I wanted to mix things up this time, starting with the wheels. I've got a jump on them: Tune 70/170 hubs, LightBicycle rims, Pillar Mega SS spokes, Sapim nipples. Expected weight ~950g
Plenty of things to sort out, most urgent:
1. Strip and clear frame/fork? (the black/grey paint scheme is pretty solid, so more about weight and possibly adding a custom touch)
2. Stem/seatpost
3. Brakes
kulivontot
by kulivontot
Please weigh the frameset, I've had two of these frames that have come in overweight
ukracer
by ukracer
Could you tell me about the rear triangle problem?
Is there a way i can check serials numbers or conatct Scott against a certain batch?
thePrince
by thePrince
I heard through the grapevine (local Austin TX frame builder/Scott rep) that it was a known issue with some of the R1 models from that year. I have no idea how many, or how they know which ones. Maybe try contacting your local Scott rep?
BmanX
by BmanX
Following
BIG DADDY B FLOW
AERO & LIGHT is RIGHT
Cervelo SLC 5960g/13.13 lbs
Johnny Rad
by Johnny Rad
Is stripping paint the new drillium?
I vote clear coat it along with your custom color touches - maybe thin glossy stripes?
How's the FD hanger? Does it need reinforcing or maybe replacement with a clamp-on FD hanger?
What's the build plan? Mechanical is lighter, right?
thePrince
by thePrince
FD clamp seems fine.
I have a newish Red 10spd group...FD, RD, shifters, crank. Mechanical is lighter :)
I tend to agree, stripping and clearing seems to be the new thing. I have been inspired by a few on here for sure. When they are done the right way, I think they look great, especially with a custom touch. My concern is that I might not be satisfied with the finish quality.
thePrince
by thePrince
Tune Mig 70: 75g
Tune Mag 170: 176g
Light Bicycle RR24T02 rims: 543g
Spokes and nipples should be arriving today.
thePrince
by thePrince
Weigh-in with only the headset cups and bottom cable guide on the frame. 800g even. Assuming 10g for the cups and 10g for the guide, that would put the frame around 780g. Not bad for a 56.
euph
by euph
780g is amazing for a 56cm. I assume that paintjob is one of the lighter ones though. It will be interesting to see when you strip it.
Sent from my UMI_SUPER using Tapatalk
thePrince
by thePrince
Wheels are almost done, a little more time needed in the truing stand.
Hubs: 250
Rims: 540
Spokes: 164
Nipples: 16
Total: 970
Not bad, I paid a total of 935USD for an under 1000g set of wheels.
If I could have got my hands on a 20h rear Mag 170, could have shaved about 17g for a total weight of 953g. Perhaps those 4 spokes will extend the life a bit though.
thePrince
by thePrince
After staring at a pile of new parts and a frame that isn't crooked, I couldn't wait any longer. Completed phase 1 of the build, and made a few concessions on weight where I'm not exactly sure what I want to do. Filled in with extra parts I had. After 1 ride in crappy weather on my everyday wheels, the frame is a lot smoother than the crooked one, and the new drivetrain sure feels nice :)
5495g was the weigh in for this phase. Attached is the build list. This included using the fork from other Addict which is 40g heavier since I haven't decided what stem I'll be running. Thomson's have a lower stack height than most, so I didn't want to cut the fork, then replace the stem with a larger stack height.
Obvious areas for improvement are the entire cockpit...stem, seat post, handlebars. I'm really particular about stem and seat post matching, so that will be a challenge. (Alternatively, I might be able to save about 40g by cutting 4" off the Masterpiece post). Chain is heavy, but looks nice. Brakes maybe too.
Strip and clear is still in the picture as an option late this summer.
My original goal was to keep the crooked Addict intact and use it to race crits (we have a weekly series here in Austin), but I'm having second thoughts now that I realize how poor the other frame feels.
