Training with a power meter - noob question
I finally started training with a powermeter but it turned out to be far from easy.
My main problem is staying within the power zones prescribed by my training program. It is incredibly hard to keep my effort constant (I am talking about 30-40W variations). Only when training on my rollers I am able to keep the variations within 5-10W but there it is relatively easy since I just need to keep my cadence more or less steady . So... how do other people do this? Is it something I learn with time?
It does take some time. You just need to "own" the numbers.
If you are trying to hold 200- you need to stay close to that. Not 270. Not 150.
Ease up on climbs. Keep pedaling on descents where it allows for steady power.
Most riders who never use power spike way hard at bottom of every rise and coast over the other side.
Don't be afraid to shift often.
jeroenDG wrote:I finally started training with a powermeter but it turned out to be far from easy.
If you mean while outside on the road then what you're experiencing is pretty normal.
Training intervals on stretches or road/climbs that don't involve lots of sudden gear changes/cadence changes/accelerations are easiest to keep power accurate on. So steady grades and flat roads....
Unless you're trying to train accelerations etc.
But if your target for a long ride is 240w for example then expect it to go up and down but try to keep it as close as possible.
Turn on 10-30s averaging on your head unit
alastairb wrote:Welcome; your trainer is your new best friend. By a large fan and a Netflix subscription.
Sent from my SM-G935F using Tapatalk
Can you provide data that the training benefit is superior when there is less variance from a given power target?
To the OP, if your target is 240 and you range mostly from 220-260 (your 30-40W variance) most would consider this normal. I typically use 3s smoothing.
Zone-based training gives a range which often spans 40W or more - for the most part it isn't too hard to keep to a 'zone'. Saying this I echo the comments of others that external variables can impact your ability to stay near a target, so planning the structured part of your workout on a road you can complete it is useful.
a lot of bigger guys have trouble with this,
you'll get better at it, but as said try the averaging, personally I keep it on 3 or 10 sec averaging, you should be able to keep with in about 10w then. also its hard to keep it even on the road, as inclines you'll need to push harder to get over the ridge etc, but you'll often find your backing off a bit on the down hill so it generally counters.
jeffy wrote:for some reason i dont have an issue with this (excuse the humblebrag) and i found longer that 1 sec annoying.
much more important is to have a "Av Lap Power" and/or "Lap NP" data field, and pay more attention to that,
Why would you do that for training though? I can see the potential benefit if you were pacing a TT or something.
You would get a very different training effect by doing half an interval at say 100 watts and half at 300 watts compared to a full interval at 200 but the average power would be the same. Am I missing something?
Yeah, you're probably never going to be able to hold a number perfectly, but as others said, shoot for a range. I try to keep it pretty small, though, like +-10w. So, for a 200w effort, 190-210 is the range I am targeting.
Lots of good advice here. I agree must riders go WAY to hard on inclines and then coast over the top and down. I set my Garmin to show my PZ as a number rather than a power figure to try and keep it at Z2-3 on my longer rides. IAlso having your average power set on the Garmin is useful, especially for multiple intervals using the lap button, just to make sure you don't ease up. I tend to do my intervals (i.e. non tempo/sweet spot/distance) work on the trainer where I can really do the quality work without traffic and terrain getting in the way.
Ulver wrote:jeffy wrote:for some reason i dont have an issue with this (excuse the humblebrag) and i found longer that 1 sec annoying.
you press LAP button every interval (beginning and end), and for longer rides and especially if there are occasional junctions or downhills. say a 3hr 30 ride. Warm up for 15 minutes, hit lap, hold "Av Lap" / "Lap NP" at top of zone 2 for three hours, hit lap, cool down for 15 minutes.
- Similar Topics
- Replies
- Views
- Last post
- 3 Replies
- 692 Views
Last post by AZR3
Mon Mar 25, 2019 12:58 am
- 5 Replies
- 615 Views
Last post by Berzin1
Thu Feb 14, 2019 12:22 pm
- 7 Replies
- 1108 Views
Last post by alcatraz
Sat Dec 22, 2018 11:27 am
- 41 Replies
- 3866 Views
Last post by amngwlvs
Mon May 06, 2019 2:37 pm
- 35 Replies
- 2721 Views
Last post by ghd
Fri Dec 06, 2019 4:34 pm
