Scott RC 900 SL Scale 6,22kg/Spark 7,33kg - "New" Spark page19
Gullholm
by Gullholm
So, more than half a year ago Scott as expected released info about their new Scale and Spark bikes. Around the same time xc felt more fun than ever, so I both decided to train way more serious and most importantly - build one of each!
Being a weightweenie for years and years of course I started looking at numbers, especially since new lighter forks etc also was released, and a quick summary said that it should be possible to build a sub 7kg hardtail with a "real" suspension fork (not a rigid/Lauf/something without lockout). I quickly ordered two of the old but light MCFK seatposts before they sold out and so the journey started. The plan was a hardtail below 7kg and no specific goal for the fully except that it would be light.
Way too much waiting for frames and parts, tons of time considering everything down to screws and what's maybe a slightly unhealthy passion for building/modifying bikes since being a kid resulted in that you can summarize the last 6 months with the following picture...
The project has turned into being quite crazy with sanding, drilling, modifying and custom parts made for the bikes so the latest weight goals is:
Scott Scale RC 900 SL size medium - sub 6,6kg (with pedals and bottle cage)
Scott Spark RC 900 SL size medium - around 8kg depending on setup (with pedals and bottle cage)
Plan is to build them strong enough for up to 85kg (I'm around 75kg in the summer) and hold up for lots of training and a few comps.
No tires like MaxxLite or Furious Fred, but Thunder Burts "as worst" since that is the lowest I personally consider being an actually useful mountainbike tire. (But everyone is of course welcome to think otherwise)
I'm still waiting for parts and lots of work left to do on the builds, and with life being otherwise very busy at the moment they're probably 6-8 weeks away from being finished. But since I got the frames this week I thought it was time to start a thread!
I'll put a speclist in this first post that I'll update everytime something has reached it's final weight, and hopefully I'll get below the goals I've set!
SCALE:
Frame: Scott Scale RC 900 SL size M -------------------------------- 767,4g
Rear axle: Extralite Blacklock ---------------------------------------- 29,7g
Fork: Fox 32SC w Hopp Carbon/ShiftUp cartridge/axle ------- 1239,4g
Remote: None ------------------------------------------------------- 0,0g
Headset: Extralite ------------------------------------------------- 48,0g
Starnut: None ------------------------------------------------------- 0,0g
Topcap: Included with stem ------------------------------------------ 0,0g
Handlebar combo: MCFK -17/100mm Schmolke TLO 720--------
Grips: Extralite Hypergrips ----------------------------------------- 11,8g
Brakes: Trickstuff Piccola custom silver ano ----------------------- 343,3g
Caliper bolts: Extralite ---------------------------------------------- 9,5g
Discs: Ashima Ai2 --------------------------------------------------- 132,1g
Disc bolts: Extralite ------------------------------------------------- 10,4
Wheels: Extralite HyperBoost, Sapim CX Super, 77Composites -- 1086,6g
Tires:
Tubes:
Rear derailleur:
Shifter:
Wires/housing:
Cassette:
Chain:
Chainring:
Crankset:
Bottom bracket:
Pedals:
Seat clamp:
Seatpost:
Saddle:
Other:
TOTAL:
SPARK Super Light Version:
Frame: Scott Spark 900 SL w/ Hopp Carbon parts- 1641,3g
Rear axle: Extralite BlackLock --------------------------- 29,7g
Fork: Fox 32 SC Factory ---------------------------------- 1326,4
Remote: Custom Scott Twinloc -------------------------- 42,0g
Headset: Extralite Ultratop/Scott bottom -------------- 54,9g
Topcap: Custom made carbon/cork--------------------- 1,2g
Handlebar combo: MCFK stem bonded to a
Schmolke TLO 720mm by Mattias Hellöre ----------- 174,0g
Grips: Extralite Hypergrips -------------------------------- 11,8g
Brakes: Trickstuff Piccola --------------------------------- 337,5g
Caliper bolts: Extralite Extrabolt ------------------------- 9,5g
Brake discs: Ashima Ai2 ----------------------------------- 130,7g
Screws for discs: Extralite Extrabolt -------------------- 10,4
Wheels: Extralite HyperBoost hubs, hand polished
Sapim CX Super, 77Composites rims ------------------ 1086,8g
Tires: Schwalbe Furious Fred LiteSkin ----------------- 710,6g
Sealant: --------------------------------------------------------- 83,5g
Rimtape: Orange Seal --------------------------------------- 6,7g
Vavles: Tune --------------------------------------------------- 7,0g
Derailleur: XX1 with Hopp Carbon Parts/Extralite --- 197,0g
Shifter: XX1 slightly tuned --------------------------------- 95,9g
Cables: PowerCordz (shifting and remote) ------------ 72,2g
Cassette: XX1 ------------------------------------------------- 263,3g
Chain: PYC SL ------------------------------------------------ 218,0g
Chainring: Garbaruk 36T ----------------------------------- 75,3g
Crankset: Tune BlackFoot ---------------------------------- 332,0g
Bottombracket: RaceFace (no sleeve) ------------------ 56,0g
Pedals: Crankbrothers Eggbeater 11 Ti ----------------- 179,2g
Seatpost clamp: Tune Würger Skyline ------------------- 5,4g
Seat: Berk Composites --------------------------------------- 60,7g
Seatpost: Schmolke TLO 31,6x400mm ------------------ 112,5g
TOTAL: 7331,5g
Total with the following tires:
Thunder Burt 2,1" LiteSkin (848,3g + 87,4g sealant): 7473,3g
Rocket Ron 2,25" LiteSkin (1063,3g +100,8g sealant): 7701,7g
Rocket Ron 2,25" SnakeSkin (1203,3g + not tested, calculated on 100,8g sealant): 7841,7g
SPARK "Heavy" Version:
Caliper bolts: XTR ------------------------------------------ 10,5g
Brake discs: Ashima Ai2 ----------------------------------- 140,5g
Screws for discs: Titan ------------------------------------- 14,5g
Wheels: Extralite HyperBoost hubs, Sapim CX Super
spokes, DT Swiss XRC950T rims ----------------------- 1169,3g
Tires: Dugast FastBird Flying Doctor ORI 50mm
including glue and sealant --------------------------------- 1178,6g
Cassette: XX1 ------------------------------------------------- 267,6g
Chainring: Garbaruk 36T ----------------------------------- 75,4g
Crankset: RaceFace Next SL slightly tuned ----------- 356,2g
Pedals: Xpedo M-Force 8 Ti ------------------------------- 213,0
TOTAL: 7862,1g
Variant with Tune cranks and CB pedals: 7804,0g
BmanX
by BmanX
Following
BIG DADDY B FLOW
AERO & LIGHT is RIGHT for 2 decades
Gullholm
by Gullholm
I'll start right away with the frames.
Been nervous about putting them on the scale since the day I ordered them, and unfortunately the hardtail was a disappointment.
Completely stripped frame including Sram/Shimano hanger and brake caliper bracket was 867,1g and to that you have to add about 15g for cable ports which makes for a total around 882g compared to the claimed "849g including all hardware". I've seen another one within a couple of grams of this, so seems they are around this weight.
The Spark on the other hand was impressively accurate. Frame including rear shock (but no remote), Sram/Shimano hanger, brake caliper bracket, cable ports for a "regular" setup and 3 bottlecage screws was 1752,2g compared to the claimed "1749g including all hardware).
So it sucks about the Scale since that bike is my number one priority and this put my calculations a bit off, but with some tricks up my sleeve it should all work out in the end.
damond
by damond
Sir, you got my attention!!!! :thumbup: :thumbup: :thumbup:
Quite impressive weight for the Scale anyway! Really curious to see how they perform! I built a 2014 Scale 900 SL which weighted 1040gr for the frame naked and i considered it a light frame...
Please keep us updated, this is a mandatory thread to subscribe! What wheels are you building? My guess would be something like 77composite rims, laced to some extralite hubs with some cx-super spokes?
Gullholm
by Gullholm
damond wrote:Sir, you got my attention!!!! :thumbup: :thumbup: :thumbup:
Same here, been a long time since I've been this excited to simply try a new bike and see how it rides! Actually my last hardtail was also a 2014 Scale 900 SL, great bike and had it down to 7.97-8,3kg depending on setup. But it's a huge drop down to 6,6kg hence my excitement haha.
That is a scary good guess. :shock: :lol: I do have some surprises when it comes too looks though, so stay tuned.
In the meantime I can show some work I've done on the XX1 derailleur for the Spark. From 245g down to 208,4 with some tuning, Extralite pulleys and a Fibrelyte backplate. Quite disappointed on the Fibrelyte though. On the stock Sram cage the threads for the upper pulley wheel inserts a bit into the wheel itself and uses a shorter screw than the lower that is flat. On the Fibrelyte both threaded inserts are flat though, so the upper screw that is shorter only grabs the threads for maybe 1,5 turns. Feels like they've taken a quite sketchy shortcut, even though people seem to run it like that and they give no info about it in any product description I've seen. So gonna get a longer screw and then I think it's finished for now.
burglarboycie
by burglarboycie
Well this is going to be one hell of an interesting thread!! Seriously sexy frames!! And nice tuning work already, can't wait to see more.
stoney
by stoney
Getting one of the new Scale RC framesets to build up is definitely on my wish list so I'm excited to follow this thread.
Johnny Rad
by Johnny Rad
When you're in, you're ALL IN!
As a Scale 29er Pro owwner, I'm definitely following your build to see what's possible.
For perspective, your Scale frame only weighs 1/3lb or ~150g more than my Addict road frame. My Addict won't see a tenth of the pounding that your Scale will see on the trail - and all for just 1/3lb or ~150g more. I think that's borderline amazing (either mine should be lighter or yours should be heavier).
Gullholm
by Gullholm
Thanks for the interest guys!
And speaking of all in - there's no turning back now... :lol:
The paint seems to be way heavier than I expected and if this continues I'll hopefully drop 60 grams or more!
Johnny Rad: Yes it certainly is an amazing weight either way, truly getting down into roadbike territory. Happy with your Scale Pro?
Johnny Rad
by Johnny Rad
Yes, I have a lot of fun on it. The trails are beautiful.
I wanted it bad, but rarely ride it. The allure of MTB is strong, but I sadly don't dedicate any time to it.
Too easy to roll out of the garage and immediately be on a road ride vs loading up my car with the MTB and driving there / back.
tonytourist
by tonytourist
A guy posted his stripped Scale on R2Bike's Facebook page in January, I thought I saved a picture of it but apparently I didn't. It looks good though and I'm sure yours will too. Good luck removing the paint! Looking forward to both of your builds.
Gullholm
by Gullholm
Johnny Rad wrote:Yes, I have a lot of fun on it. The trails are beautiful.
Sounds great, but I fully understand this. Luckily for me the trails start not even 1km away from home along with a vast network of gravel roads.
tonytourist: Thanks! Yeah I saw that, he has a thread going on mtb-news.de forum and I think he has it down to about 7kg by now. He lost 91g stripping it if I remember correctly, but mine will be a bit less since the SL has decals instead of painted logos like the others. Still baffles me though that bike companies spend tons of R&D money and time shaving grams off their frames and then put paint on adding almost 10% of weight.
But I don't know, maybe the lighter paint options are that much more expensive or there simply aren't enough people/weightweenies around who cares haha.
poynt
by poynt
Having seen the claims by Scott that the new Scale would be 849g I was looking forward to seeing some 770g+ frames appearing, but it appears that the weight is similar to other yrs. I sanded down my Scale Premium 2011 M and managed to get it down to 816g from 892g with decals and a waxed finish. I also just got a NOS Scale RC 2014 in a small that I plan to do the same with as the medium was just a little too big for me.
Gullholm
by Gullholm
poynt: Yes a bit disappointing, but paint stripping and something special when it comes to mech hanger and cable ports and I still hope to get just below 800g, we'll see.
Busy days so I still got a lot of work left on the frame, but here's some sanding and polishing from a couple of weeks ago.
Sapim CX Super (and yes, the work was just as time consuming and tedious as you imagine it to be haha)
mattyNor
by mattyNor
Maybe a stupid question but why not just get silver spokes?
Sent from my SM-G930W8 using Tapatalk
