Scott Addict SL Tire And Rim Clearance
Beaver
by Beaver
Hi, will the actual model (2014+) fit real 28mm wide tires and rims? Thanks!
fitty4
by fitty4
I have a addict team issue with vittoria corsa 25mm tires, there is plenty of space in the rear, in the front the smallest distance between tire and fork is about 3mm. I ride narrow rims but wide rims shouldn't be a problem since the fork is wider where the brake track is.
Orica green edge and team I am has also used the bike for the cobbles with 28mm tires
Beaver
by Beaver
Hi, checked an Addict 20 2015 at a local shop: more than 25mm were not possible. Did Scott change tire clearance in 2016?
lord_brush
by lord_brush
I've got a Team Issue from 2014 also, and run 25mm Michelin Pro4 ENDURANCE tyres (on Ksyrium SR's)...which are renowned for being oversized and more like 28mm.
So...I'd say YES, 28mm fits.
The right to bear arms is slightly less ludicrous than the right to arm bears. (Chris Addison)
Delorre
by Delorre
See page 4, a couple of pics of mijne, new Michelin power comp 25 on récent bora's. Real size is 27mm wide and 25 high. A true 28 will fit, a 28mm gp 4000s won't. Hope this helps. viewtopic.php?f=10&t=144273&hilit=Addict&start=45
kulivontot
by kulivontot
For reference: 2015 addict sl
Rear chainstays
Front fork
25mm schwalbe pro one tubeless on Amclassic road tubeless
Beaver
by Beaver
Thank you! That looks like the 2015 one I saw at the lbs. I hope you don't ride it like that, it's just too close. An untrue wheel or a broken spoke would be dangerous.
It's also possible that Scott has different suppliers for the frames...
Delorre
by Delorre
Beaver wrote:Thank you! That looks like the 2015 one I saw at the lbs. I hope you don't ride it like that, it's just too close. An untrue wheel or a broken spoke would be dangerous.
More than 20.000km on mine with the same few mm clearance, not a single problem, not even a scratch on the frame or fork due to tyre rub. Don't bother and ride that thing!
