Just another Addict
track01
by track01
Why did you post your Speedplay weights? :roll:
After seeing this I just lost some $$$ to upgrade my X pedals with some J&L spares from fleabay. :wink:
Can't resist :!:
Imaking20
by Imaking20
Excellent finished (yeah, right) product. I'm a little surprised by the wheel choice!
Do you have a weight on your pedals after tuning?
anlimdy22
by anlimdy22
Imaking20 wrote:Excellent finished (yeah, right) product. I'm a little surprised by the wheel choice!
everything changed to ti should be 140g+
Sent from my SM-N9208 using Tapatalk
Johnny Rad
by Johnny Rad
Imaking20 wrote:I'm a little surprised by the wheel choice!
Yes, high zoot wheels are definitely on my list. Timing is TBD! :D
Then again, I'm also intrigued with an integrated stem / bar combo from Berk which ain't cheap!
Life can be hard to predict! If I knew that I'd build-up a new bike this season, I think I would've checked out lighter pedal or crank-based power options. At least I didn't break the bank when PowerTap was blowing out their GS rear hub last year at $299.
Why Reynolds Attack? I've had a couple sets of Reynolds wheels over the years and they've all been top-notch (DV UL tubies, Attack twice and Assault). Plus they're local to me here in Utah and that's nice.
Johnny Rad
by Johnny Rad
anlimdy22 wrote:
Imaking20 wrote:Do you have a weight on your pedals after tuning?
Sadly, I missed weighing and posting them. Seems I bought my current Speedplay Ti Zero pedals way back in 2012-2013 (!!!) and there's no posts here or pics on my HD. Shame on me! :noidea:
If the Ti Zeros are truly 82g/ea, that makes for 164g/set. Minus the 18g savings from the Ti butterflies and bolts (just $14 shipped including 8x Ti cleat bolts!) and my pedals should be ~146g/set.
As I look back, these pedals have been very good to me. I serviced them annually and re-built them with OEM parts 1-2 years ago. The only tuning is the butterflies and 4 mounting bolts that took off 18g.
Imaking20
by Imaking20
I can appreciate Reynolds (just picked up my fifth set). Those clincher Attacks seem like a fine do it all setup and, honestly, makes your weight that much more impressive. Really looking forward to seeing something a little more fancy!
Thanks for the comments on the pedals! I may head back and give Speedplay a try. It's been a few years.
Johnny Rad
by Johnny Rad
Replaced my Speedplay Zero cleats with new Zero walkable cleats this weekend. Turns out the walkables use shorter mounting bolts that are about 1/2 the length. The longer length J&L Ti bolts that I just bought are therefore too long. All in all, I saved 5g on my shoes by moving from OEM to J&L but have now added back a gram.
8 OEM mounting bolts for Speedplay walkable Zero cleats
8 OEM mounting bolts for Speedplay old-style (?) Zero cleats
Johnny Rad
by Johnny Rad
^^^ Speedplay's walkable Zero cleats are working out fine. They do make walking easier, but certainly not foolproof! Will say that I've had to really crank down on the 4 mounting bolts per cleat tighter than expected to keep the cleat in place. These new mounting bolts are ~1/2 the length of the non-walkables so there's less of them to hold the cleat in place. All good now, but a smidge longer would've given them more bite...
Johnny Rad
by Johnny Rad
This just in - 7g savings! Stop the presses...
Finally swapped out the factory Syncros / Scott seat post clamp (13g incl hardware) for a nice carbon piece from Pitor Smuda @ SMUD Carbon (13g incl hardware).
THIS ISN'T TRUE. I owe Piotr a most heart-felt apology. Once I went back through my email correspondence to find this answer, I see that I asked for a "single arm" seat post collar and that's exactly what he sent me. That was terrible of me... Piotr is a good guy and shipped it out quick enough to keep me happy. I wanted his twin-arm version (http://smud-carbon.eu/clampCL.html), but this is what showed up. Maybe his website is out-dated? The weight is good, so I'll happily keep this one. :D
Johnny Rad
by Johnny Rad
Probably gonna be a lot faster...
Kogel's 11t jockey wheels for SRAM Road.
Road report and OEM SRAM eTap jockey wheel weights to follow.
For the record, my Kogel BB86 PF still spins like a champ and (knock on wood) no creaking. [For the record, it lasted a year before developing a low torque creak. Replaced it with another Kogel.]
Johnny Rad
by Johnny Rad
Johnny Rad wrote:Kogel's 11t jockey wheels for SRAM Road.
Saved a whopping 2g by moving from the OEM SRAM Blackbox ceramic (?) jockey wheels to Kogel...
Not sure what to say about a ride report, but the Kogel jockey wheels work as advertised. Plus they're blue. And that's cool. And probably fast.
Johnny Rad
by Johnny Rad
Mep wrote:...Not even sure I understand how you're able to achieve that with 1.5kg wheels.
Changes coming! Hope to save 50-100g by changing out the Reynolds-branded hub and DT Aero Comp spokes for this and CX-Ray spokes.
[Ended up saving 58g on my front wheel when all was said and done - 51g on the hub and 7g on spokes.]
KaneChang
by KaneChang
Johnny Rad wrote:This just in - 7g savings! Stop the presses...
Hello, nice upgrade :thumbup:
What size do you choose? Thanks :beerchug:
Johnny Rad
by Johnny Rad
KaneChang wrote:Hello, nice upgrade :thumbup:
I ordered 30mm from Piotr @ Smud Carbon. It works as advertised.
And I owe Piotr a most heart-felt apology. Once I went back through my email correspondence to find this answer, I see that I asked for a "single arm" seat post collar and that's exactly what he sent me. That was terrible of me. I've edited my erroneous post above.
KaneChang
by KaneChang
Thanks Johnny :beerchug:
