Dura ace 7900 shifters with 9100 breaks ?? Compatibility
Allen254
by Allen254
They are not much lighter than my current ultegra 6800 but the dura ace brakes have very nice stopping power.
Also I was thinking of TRP R960 ti brakes any expirence with these ?? 230 grams for the pair.
I have 7900 dura ace shifters. So in wonder if the 9100 brakes are compatible??
Ritxis
by Ritxis
Allen254 wrote:They are not much lighter than my current ultegra 6800 but the dura ace brakes have very nice stopping power.
Yes, no problem
CrankAddictsRich
by CrankAddictsRich
I guess it depends on your definition of compatibility.... can you hook them up? yes. Is it a good idea to do this? no.
https://www.youtube.com/watch?v=beSUvIIwOto&feature=youtu.be&t=1m7s
2016 Pactimo Brand Ambassador
http://www.Crankaddicts.cc
2017 Specialized S-Works Tarmac SL5
2015 Specialized S-Works Allez
2014 Specialized S-Works Shiv TT
2015 Specialized Venge Pro (Retired)
Allen254
by Allen254
CrankAddictsRich wrote:I guess it depends on your definition of compatibility.... can you hook them up? yes. Is it a good idea to do this? no.
interesting thanks for that video.
steelbikerider
by steelbikerider
I used 9000 brakes with 7900 shifters for a few years with no issues. Not quite 9100 but close.
shonanmike
by shonanmike
Brakes.
Mackers
by Mackers
The video discusses the 7800 model, not 7900.
7900, 9000 and 9100 all use the same cable pull.
tilf
by tilf
Compatible and should be no issues. The BC-9000 (DA brake cable/housing) is also a worthy upgrade while you are at it.
mattr
by mattr
Gear cables under tape = new brake pull ratio.
Exposed gear cables = old brake pull ratio.
I had to check this last year when i started mix n match of 9/10/11 groups. Before then I'd not had to mix anything.
FWIW the 9 speed calipers work passably well with my 10 speed shifters.
WhyZ
by WhyZ
I used 6700 ultegra shifter and 9000 brakeset.
No problem.
9000 brakes is very goooooooooooooood. Perfect!!
VforVonnegut
by VforVonnegut
Shimano has not updated the cable pull since 7900, so you're fine.
