Climbing bike project ideas....!!!
sugarkane
by sugarkane
Neckkoss wrote:It is going to look a lot like sugarcane's z5 sli but with etap and lightweight wheel set.
8) got Etap now Image
Neckkoss
by Neckkoss
Sugarcane help me out here, could you explain in detail your thm bb pf30 install on your frame, my drive side cup is loose by 0.5-1.0mm. Did you use spacers? Loctite ? I'm open to any suggestion before I go from pf30 to permanent pf30 to bsa adapter with carbon fiber resin
Zoro
by Zoro
I've got a few finishing touches on a climber I did.
Finished ready to ride is at 5.64kg (12.4lbs) now. That is with water bottle cage, spoon (heavy) Garmin mount and DA Pedals. I can shave another bit off that, but close enough for now.
Cranks are DA, and full Di2. Brakes are the KCNC things. They don't stop well. BB is WheelsMfg. Power Cordz brake cables (Di2 shifters). Stem is Ritchey SoloStream. Wheels ready to ride with cassette (RECON), tires (Vittoria Speed G+), glue, skewers(KCNC Ti) - 1380g.
The goal was power transfer 1st, light 2nd. I will stick with the DA parts.
https://1drv.ms/i/s!AoUfGFf09F_frIIsm_Xy-OwxIwyAxA
https://1drv.ms/i/s!AoUfGFf09F_fq_51mxoP80PGeIi5Vg
Neckkoss
by Neckkoss
A few changes on the build were done but I will continue improving it
Neckkoss
by Neckkoss
Neckkoss
by Neckkoss
Neckkoss
by Neckkoss
Neckkoss
by Neckkoss
milesthedog
by milesthedog
While I have the Jagwire linked housing, Jagwire is putting out some new super light shift housing and cables this year (saw a quick review from tapei) that would probably be the best option. Fairwheel has some good deals on the Schmolke rims.
chefczyk
by chefczyk
i think your bike is trying to tell you its "lightweight"
egebhardt
by egebhardt
I'm surprised to see any stem caps on top of the steerer tube. once the stem is pinched onto the steerer tube, take off the cap!
Eric in San Carlos, CA
Conza
by Conza
chefczyk wrote:i think your bike is trying to tell you its "lightweight"
:lol: :lol:
It's all about the adventure :o .
