S-Works SL 2018
morganb
by morganb
CrankAddictsRich wrote:
Wed May 16, 2018 12:32 am
A few weeks back, my local shop had a kit release party night. They had a bunch of awesome bikes tthat they've built over the last year on display and of course a bunch of bikes for sale as well. Toward the end of the night, a friend and I were looking at the teal/black expert that they had hanging up towards the ceiling of the store. At that point in time, my friend was debating doing exactly what you're gonna do, buy and strip it. We were all standing around looking at the bike, guessing what it weighed, stock. We all placed our bets and one of the shop mechanics finally puled it down and weighed it. Most of the bets were in the 17.0 pound range. If I recall correctly, I think it was 16.4 pounds in a size 54. That was stock build, no pedals, no bottle cages. I thought that was pretty darn light considering those wheels are probably pretty hefty and it's an Ultegra mechanical build.
That's good news, I should be able to get close to 15lbs with aluminum wheels then. Will lose some weight from the saddle and cockpit too.
poppiholla
by poppiholla
Finally in the house. My Tarmac S-works SL6
Frame: Specialized Tarmac S-works SL6 Cameleon Green (size 58)
Shifting: Sram Red Etap
Crankset: Sram Red Quark Dzero 175mm
Cassette: Sram Force 11-28
Chain: Sram Red
Wheels: Fulcrum Speed 55C
Saddle: Fizik Antares R1
Handlebar: Specialized S-works 44cm
Stem: S-works SL 11cm
Bottle cages: Tune Wassertrager
Brakes: Shimano Ultegra Direct Mount (when available replace by Sram S-900 direct mount)
Seatpost: S-works
Tires: Schwalbe One 25mm + Conti 80mm binnenbanden
Garmin: Edge 1030 + Garmin out front mount
Pedals: Look Keo Blade 2 (20nm)
Handlebar tape: S-works cork
Weight all in: 7.2kg
Setup will probably change a little bit. Stem is correct height, but I have to check first. Decals on Fulcrum wheels are waterslide decals. Very thin. Probably removable with Microscale Microsol if the decals are not beneath clear coat. I need confirmation about this. I like the grey decals on the wheels but the red ones are probably a little bit too big. I will also check the weight of the bike with my Lightweight Meilenstein C wheelset. I will make pictures. Tomorrow I will test the bike. ;-)
Ciao
mbdurham17
by mbdurham17
Ready for a bath after a nice long Saturday ride through some mixed roads ImageImage
mbdurham17
by mbdurham17
CrankAddictsRich wrote:^^^ what wheels? They sort of have the Zipp coloring. 404's?
Yep 404’s with all decals removed
sychen
by sychen
mbdurham17 wrote:Ready for a bath after a nice long Saturday ride through some mixed roads
Love your taste in bike/bar tape and car (5 series?)
TonyM
by TonyM
mbdurham17 wrote:Ready for a bath after a nice long Saturday ride through some mixed roads ImageImage
Such a stem deserves to be slammed Image
mbdurham17
by mbdurham17
Thank you very much and yep good eye 2016 M5 CP tuned to around 700hp
mbdurham17
by mbdurham17
Haha yea definitely agree I’m getting there noticed I had to add a spacer to keep the same fit as my SL5 with just a cone and already a little lower my flexibility is getting better Image
morganb
by morganb
Gen 3 eeBrakes were on closeout on Fairwheel, so snagged a set for the Expert build, bike is coming Tuesday but probably won't get it finished until the weekend pending parts arriving. Will post bare frame weights once I get it broken down.
morganb
by morganb
930g with cage bolts, cable guides, mechanical stops and BB guide, and hanger. Hoping to build up Thursday as I'll be racing tomorrow.
ODC
by ODC
Anyone knows which BB from ceramic speed I must buy for the Shimano crankset?
- BB30 Shimano Road
- PF30 OSBB Shimano Road
If I look at the bikes from quick-step then I see adapters that looks more like the BB30 adapters then the PF30 adapters
Beaver
by Beaver
morganb wrote:
Wed May 23, 2018 1:40 am
Size?
ODC wrote:
Wed May 23, 2018 6:59 am
- BB30 Shimano Road
http://www.ceramicspeed.com/sport/produ ... ano%20Road
jhalmar
by jhalmar
Size?
- BB30 Shimano Road
I am pretty sure that PF30 is wrong version. The right one is BB30 version.
OSBB information: https://www.kogel.cc/blogs/kbba/special ... -explained
And yes, I have S-Works Tarmac disc SL6 and just installed Praxis Works GXP conversion bottom bracket BB30 version.
morganb
by morganb
Beaver wrote:
Wed May 23, 2018 12:22 pm
Size?
- BB30 Shimano Road
It's a 52cm
