S-Works SL 2018
cveks
by cveks
tommyb wrote:
Thu Mar 29, 2018 4:37 pm
Finally received and built this, and very happy with it. 5.81kg
Impressive
share link to full spec?
Dogmatic13
by Dogmatic13
Hi all, tried the search and also Google but couldn’t find this info.
Any S-Works SL6 owners care to confirm if the supplied FACT seatpost saddle clamp mechanism can accommodate carbon 7x9 rail saddles, or do I need to stick with 7mm round rails.
Want to use a Selle Italia SLR Flow Kit Carbonio that has 7x9 oval rails but if the seatpost saddle clamp can’t take this, then I will use the version with manganese rails, which is 7mm round.
Thanks!
sychen
by sychen
Comes with both cradles to handle round or oval 7x9mm carbon rails.
You'll be able to use that saddle with no issues.
Sent from my SM-G950F using Tapatalk
ProfessorChaos
by ProfessorChaos
mbdurham17 wrote:
Wed Apr 04, 2018 2:29 am
Opinion: Thinking about swapping from my 2016 zipp 404 to roval clx 50s (maybe tubulars) to save about 300g .....does anyone have experience with both and can comment one way or the other? This would get me down to around 14 lbs. My zipp 404 are the only wheels I have used since I switched to road from mountain bikes about a year ago
I had 2010 Non-Firecrest Tubular 404's, and I have 2013 808 Tubulars. All the Rovals I've used have all been clinchers so they have been heavier, but also much stiffer. I have both CLX64, and 50's currently, and I really love the CLX 50's. I want to sell my 808's, and buy some CLX50 Tubulars. I suspect that is the ultimate wheel, for stiffness/weight/aero.
Dogmatic13
by Dogmatic13
sychen wrote:
Sun Apr 15, 2018 12:30 pm
awesome! thanks for the input
mbdurham17
by mbdurham17
Exactly what I was looking for thank you
Dogmatic13
by Dogmatic13
Anyone got any size 49 SL6 pics of their setup?
I test rode the one below and that’s been adjusted to my fit (694mm saddle height, 100mm stem,). My height is 165 but I’m more leg than torso. Front end on this was high though, so will drop a spacer and not do the hoverbar. Also the saddle is weird and I always do a SLR fully level.
Aesthetic wise must admit the slope is severe, but when you run a decent saddle bar drop, I find it balances out. Tried a 52 too but no way I could get a comfortable fore-aft. Zero offset might help, but not sure. The 49 fit me well on my 1hr test ride. Also ride a 45s C60 and a 465 Dogma. Both are a great fit, albeit the C60 feels a tad long.
I’m keen on the pink camo SL6 but can’t find good pics of it in 49. Anyone got pics of this, or other 49 setups?
.Image
tommyb
by tommyb
cveks wrote:
Sun Apr 08, 2018 9:25 pm
Impressive
Thanks :thumbup:
56cm SL6, weighed 840g bare frame.
eTap groupset with climbers blips on bars
BERK composite 40cm/12cm shallow drop bar/stem combo with custom Garmin mount
Lizard Skins Race DSP tape
Look Carbon Ti pedals
S-Works 175 carbon cranks with P2M Type S spider
52 tooth Carbon-Ti outer, 39 tooth Praxis Works inner rings
Lightweight Meilenstein Obermayer's, Conti Competition 22mm tubs
EE SL6 Specific calipers
S-Works Power saddle
SL6 Propriety post
Total weight: 5.81kg
jj911c2
by jj911c2
Fantastic build tommyb - 5.81kg is impressive!
moyboy
by moyboy
great build! a step away from the tan walls and rovals.
Rafaqs
by Rafaqs
My new baby
morganb
by morganb
As availability is getting thin on the rim brake bikes I'm torn whether I should pull the trigger or wait to build a disc bike later in the year. I have almost everything I would need for the rim brake model save DM brakes. I have a dedicated rain bike so it's mainly a matter of future compatibility and weight.
Jian81
by Jian81
Dogmatic13 wrote:
Wed Apr 18, 2018 3:15 pm
.Image
Woah ECP? Haha =). Sorry but i cant help you as i run a sz 56.
Devastazione
by Devastazione
Hot bike man. What skewers are you using ? Birthday is coming and wife need ideas.... :mrgreen: :mrgreen:
alexmcm09
by alexmcm09
Finally received my Tarmac Pro, it was a long long wait after putting down the deposit in November.
I'm stoked with the paint scheme, photos definitely don't do it justice. It must add a ton of weight to the frame but damn it looks good. Specialized have really raised the bar on paint schemes of late - I've had lots of people ask if it's a custom paint job.
I'm still to change over the stock bars and stem to a set of Aerofly bars and Zipp Speed SL stem, just waiting on my bike shop to have time to internally route the bars.
Final weight should be a tick over 7kg with pedals included in a size 54, I'm pretty happy with that for a Pro level frame. Now to start saving for some ee brakes...
