FAILURE Shimano Cranksets
Frankie - B
Administrator
by Frankie - B
I've seen it with a ultegra crank as well.
Please follow me on Instagram
antonioiglesius
by antonioiglesius
I thought there would be screws holding the two halves together in addition to the adhesive...
goodboyr
by goodboyr
dynaserve wrote:
Calnago wrote:It's just cosmetic.
Bit more than cosmetic, but luckily the failure mode is ideal to simply Loctite it back in place.
Duct tape.....
victorduraace wrote:Must be something in glue/bonding method susceptible to failure in wet and hot conditions
Sent from my SM-G900W8 using Tapatalk
hambini
by hambini
JB Weld.
Hambini Aeronautical Engineer, Polluting YouTube since 2016 - views expressed are my own...
Add me ON TWITTER!
Aerodynamic Masterclass in bicycle wheels
I fixed the bottom bracket from hell
toshi
by toshi
F45
by F45
Ah, so that explains why the 11 speed groups are so inexpensive. Instead of welding, they glued their cranks together.
wheelsONfire
by wheelsONfire
What am i supposed to say who just cracked a welded rim?
Bikes:
viewtopic.php?f=10&t=156137
Open *UP* (2016.04.14)
Ex bike; Vial EVO D
Darceking
by Darceking
This happened to my DA9000 Crankset. And no, it had nothing to do with the Pioneer
https://instagram.com/p/BEWuJjnLPnz/
nickf
by nickf
My buddies ultegra crank did this just a couple months ago. Didn't fully choke apart but was just about to let loose.
nickf
by nickf
Double post
nickf
by nickf
This just came into the shop today.
thedonnydino
by thedonnydino
I had a duraace 9000 crankset fail. No power meter.
Seems like the epoxy that holds the crank together.
Took off from the light, heard a crack, and noticed a whole lot of flex through the crank.
It didn't separate completely though, but I imagine had I put some power through it at the time it would have.
wheelsONfire
by wheelsONfire
It seems this is due to corrosion, humidity and salt?
Perhaps in conjunction with a twisting load when we pedal it work itself off or in some cases crack?
So Shimano Hollow Technology is bascially a U-profile with a reversed U-profile glued on?
Bikes:
Ex bike; Vial EVO D
shoemakerpom2010
by shoemakerpom2010
Interesting you say failure due to salt.... I had a highend mtn bike bullseye rimset hand built and they lasted 15 years with zero problems until I moved to Florida... After that the flange on the rear hub cracked and failed....After which I come to find out that Bullseye had a small clause about salt weather on the hubs and failure if they were exposed too long in such climates.... :noidea:
de lars cuevas
by de lars cuevas
Hi there,
Hollowtech is a hollow forged crank.
Hollowbond is a crank made of two hollow shells bonded together.
DA9000, DA9100, Ul6800 and XTRM9000Race are Hollowbond, all other cranks are, to my knowledge, Hollowtech.
