Giant Propel owners
upside
by upside
Could someone please tell me if the brake housing runs through the top tube or is there housing stops at the front and rear of the top tube. I picked up a slightly used frame and will be putting it together soon and never have worked on a Propel.
bungis
by bungis
The brake housing does not run thru the top tube. If you can find where to buy the stops online give us a link :thumbup:
(Haven't looked myself, but need it soon)
davetung
by davetung
Cheetahmk7
by Cheetahmk7
They have housing stops and just the cable that runs through the top tube.
If you are lucky the previous owner will have left the cable in and you can heat shrink it to your new cable in order to pull it through. If the previous owner hasn't done that you will be able to get the cable to exit but it will be fiddly.
upside
by upside
Can I use typical brake ferrules for this or do I need special stuff from Giant.
Multebear
by Multebear
bungis wrote:The brake housing does not run thru the top tube. If you can find where to buy the stops online give us a link :thumbup:
+ 1
Yes, you just use regular ones.
upside
by upside
Thanks.. got it all figured out and start the building process..yeeeehaaaa. Thanks for the help guy's. Does anyone recommend a barrel adjuster on the brake???
