Third Time's a Charm: Litespeed T3
terrible1
by terrible1
i asked you about your dimensions on this bike years ago.
the other day, i finally picked up a t3. i'm over the moon with it.
two rides in and it's faster than my scott addict regardless of extra weight.
what year is yours?
look forward to refining it from its state when bought and sharing here eventually.
RyanH
by RyanH
Mine is a 2015
Strava
Not for the sensitive types. My Instagram reviews
The Ex's: I've lost track...
terrible1
by terrible1
RyanH wrote:
Tue May 26, 2020 9:17 pm
Mine is a 2015
Rad, mine's a '14.
RyanH
by RyanH
Back on a PC8. Unfortunately it's a +80g change over the Alptitude and Garmin 130 combo but man I missed this screen:
I ended up with two Rec-Mounts faceplate mounts, and as per usual they're porky. I'm using the heaviest option since I'll be able to mount a light when the time changes but the standard srm bar mount is the lightest.
Alptitude and srm bar mount (with steel bolt):
Strava
Denavelo
by Denavelo
There was a T3 on ebay BUY IT NOW for like $750 in my size. I hesitated for a most of the day and it was gone that quick. Still kicking myself for not buying it..
your build is super clean. Looks like the perfect LA shredder. Snappy in climbs, and compliant enough for broken pavement.
Speedvagen Road Machine "2011 Surprise me | Rob English "Mudfoot" 29er | Focus Izalco Max
RyanH
by RyanH
Did a little gram shaving:
Tesa Tape ended up being 12.5g for the bar tape. Holding up well so far.
Put Ilinks back on for brake housing mostly because I cut the housing too short on the Shimano polymer housing:
Swapped stem to 3t ARx 140mm to see how it'd look. I think an Enve 140mm stem is probably the sweet spot for chunkiness to transition the heat tube.
Currently sitting at 6.3kg:
Strava
Imaking20
by Imaking20
Wow. Heavy. What would you say your embarrassment is like on a scale of 1-10?
RyanH
by RyanH
I'm definitely at an 11. I had this bike sub 6kg at one point and can't quite figure out where I've gone wrong in life.
Also, fixed the pixelated image:
Strava
AnkitS
by AnkitS
And to think that it's replacement will be even heavier :oops:
Why I quit WW. Bike updates all on instagram
RyanH
by RyanH
Sourced an Enve stem, probably the best balance of chunkiness for the abrupt HT transition:
Strava
themidge
by themidge
Is that a 140? Looks absurdly long on the small frame :D
jbaillie
by jbaillie
The softer finish on the Enve stem also matches the fork & seatpost.
Also is it just me or do Veloflex gumwalls attract dirt more than any other? My Masters are basically black at this point and it won't come out with any of the old tricks (toothpaste, magic eraser, Tide, etc.).
RyanH
by RyanH
@themidge yup, 140. Been on 140 for awhile on this bike.
I seal my sidewalls with tent sealer (Vittoria comes sealed already). These tires are near end of life at this point. They looked great for about 6 months. I admittedly haven't attempted to clean them though. Maybe I should get around to cleaning my bike...
Strava
foregroundmusic
by foregroundmusic
The Enve stem looks nice, but I'm definitely still partial to that Zipp stem for some reason.
Is the plan to move everything on this to the Ultimate now? I happened to see the classified posts on Paceline for the other stuff from that build
AnkitS
by AnkitS
+1 zipp much better, -6 doesn't look as nice.
