Best Aero handlebar?
DuncanS
by DuncanS
I'd day most of the gains are from narrower arm position. I'm presuming the aero profile 42 is narrower at the hoods.
Sent from my GT-I9507 using Tapatalk
wingguy
by wingguy
DuncanS wrote:I'm presuming the aero profile 42 is narrower at the hoods.
Not the way Zipp measure their bars.
hongsj
by hongsj
enve ses aero handlebar.
Hexsense
by Hexsense
Well, my 40cm at drop end Enve SES Aero road handle bar (~36cm on the hood) 's mounting surface rough coating has strip badly after year and many times of stem changing/bar slipping due to bad stem/bolt become lose from vibration/crash. Now even with good stem, carbon paste and torque stem bolt to 7N.m it still slip on pothole so it's due to replacement.
My requirement limit my choice so badly since i need
-no wider than 38cm center to center on the hood. <-many bar like Easton and Pro Vibe Aero has 40 as smallest size.
-have some flare angle if possible. No need to flare as much as Enve. But something like 4 degree is sufficient.
Any other choices other than Zipp SL-70 Aero and Enve SES Aero road?
jlok
by jlok
Hexsense wrote:Well, my 40cm at drop end Enve SES Aero road handle bar (~36cm on the hood) 's mounting surface rough coating has strip badly after year and many times of stem changing/bar slipping due to bad stem/bolt become lose from vibration/crash. Now even with good stem, carbon paste and torque stem bolt to 7N.m it still slip on pothole so it's due to replacement.
The 3T Aeronova almost meet your 38cm requirement at ard 38.5cm at hood and 40cm at drop... will go home and measure just to make sure.
Thenuge
by Thenuge
So if I want to get some aero bars is the Zipp SL70 a good bet with the Zipp Sprint stem? I don't want any exaggerated reach numbers like it sounds with the 3T's. I also want something stiff but yet maybe more compliant then aluminum? But def s focus on stiffness.
Also width. I'm 6'1" or 185cm with fairly broad shoulders. I'm typically on 44cm bars but it seems like more and more people are going to 42?
Lililchti
by Lililchti
DamenH85 you've got an awesome bike, slightly jealous :D
I always need more, i work more to get more.
seansis
by seansis
If I want to install a clip on aerobar which aero handlebar should I choose?
Now I have Deda rhm 2 so I'm looking for a handlebar with similar parameters. Suitable only Zipp sl 70 aero, but it is not compatible with clip on aerobars.
If I buy 3T Aeronova, then I will have to greatly reduce the length of the stem. (now 110mm -> 80mm)
What choice do I have?
rossjm11
by rossjm11
Thenuge wrote:So if I want to get some aero bars is the Zipp SL70 a good bet with the Zipp Sprint stem? I don't want any exaggerated reach numbers like it sounds with the 3T's. I also want something stiff but yet maybe more compliant then aluminum? But def s focus on stiffness.
I found the SL70 with the Sprint stem to be an uncomfortable combo. Currently using a Pro Vibe Carbon bar, so not aero. Maybe consider the aero Pro bars too
BMC SLR01 2015
Redline Conquest Team
morganb
by morganb
The SL70/Sprint combo is my favorite front end I've ridden so far, its definitely stiff but I never found it uncomfortable, even on long rides in a very low position. I run big tires/wide rims all of the time so that might mitigate some of the harshness though.
seansis
by seansis
Will someone answer my question?
Marin
by Marin
Bontrager
rossjm11
by rossjm11
I can certainly see that. I just found the flats super harsh on the SL70s, running Zipps with 25s.
BMC SLR01 2015
inchul
by inchul
There are a lot of products these days
Is Aeronova good and not good?
sinker
Marin
by Marin
Like many things, it's both and not good, also depending what you are using it for
