Whats your commuter bike weigh?
A gigantic catch-all for Randonneuring (Audax), Bike-packing (Touring), and Commuting.
shlammed
by shlammed
Lets get it going.
Photo of the bike as weighed required if not on the scale in the photo, and any relevant specs you want to specify.
Entry #1. Cheap commuter build, not WW but not too bad considering.
Weight as pictured: 27.0 lbs.
Specs:
cheap steel frame
cheap heavy alloy post
steel quill stem adapter
Aksium Race wheelset
Continental Cyclocross Speed "35c" tires (measure 32c)
11-34 shimano cassette
shimano 105 10s levers
sram rival crank
axiom fenders
Going to change out to a 200g saddle from the 270g unit on there now and change to some modern brake calipers (in the mail) but im not looking to do much more work as it sits.
Going to be building a new alloy frame to put these components on, hopefully with some kind of carbon fork to lighten everything up.
prendrefeu
by prendrefeu
At the moment, for the past two weeks anyway, I've been riding my WW-bike as my commuter just as a test to see how it fairs on the horrible roads we have in the LA area. It's held up fine... current weight unknown, but recent part swaps and prototypes (it is an experiment, afterall) probably has it at around 12lbs even or lower (guessing).
Parts will soon be swapped over to a steel frame I've been working on, hopefully a sub-15lb commuter should smooth out the rough roads.
mattr
by mattr
Depends how long it was since i last cleaned it, and how much ick has gathered in all it's nooks and crannies.
Last time i weighed it (clean), it was just under 12 kilos. Guards, saddlebag, rear lights (no front though)
Would be ~12.2 kilos ready to commute on.
No pictures as it's a bike, i don't (often) take pictures of bikes.
Kinesis Racelight tK frame, full carbon fork, open pro, 105/ultegra mix for groupset, no idea what tyres, probably 4 seasons or gatorskins. No idea what bars or stem either, but the seat post is possibly the heaviest post ever, the only one i had to hand in the right size was a 300mm steel thing that cost me a £10 several years ago. The irony is that it's got a £100 saddle bolted to the top of it.
Snockers
by Snockers
I use my Straggler for the ~40km round trip commute on pretty varied surfaces, often stretching the ride home out a bit to make it more like a 50km round trip.
Just put fenders on the other week as it's starting to get colder/wetter down here in the southern hemisphere, but before I put those on it was sitting just under 12kgs if memory serves.
Changes from stock config: 32h Grail rims onto Surly front hub and Deore XT rear; Thomson Elite seatpost; Apex shifters and X9 Type 2 rear mech; 40t Raceface NW chainring with 11-36 Shimano XT cassette and chain; Clement X'Plor MSO 700x40 tyres. Oh, and fluorocamo bar tape.
Thinking I'll build up a slightly lighter wheelset after winter, should help to shed half a kilo or so...
Rush
by Rush
I commute on my old custom Reynolds roadie in the dry. 26 years old this year.
Weighs just under 10 kg.
In the wet I ride a cheap MTB with rack and slicks.
Probably weighs about 12 kg with rack+pannier.
I will commute on my Baum if I need to add some extra midweek kms.
bikewithnoname
by bikewithnoname
10.4kg
DSC_4124 by bikewithnoname, on Flickr
Actually it's probably closer to 10.1kg now as it's got a cambium saddle and middleburn crank these days
Stalkan
by Stalkan
Around 10 years ago I used to ride a steel KHS Flite that weighed just under 19lbs, but when I started racing I found commuting didn't fit with my training plans. Therefore, I sold that commuter bike and stopped commuting. However, with the kids getting older and my schedule having less time for training I have gone back to commuting as a way to get more ride time in. Unfortunately, my current commute is all pavement, but I love the U.P. as it is setup for the route and really enjoy my rides in and home.
Build as you see it (with 520 but minus the bottles) is 18.87lbs/8560g
Edit for specs:
Frame: OPEN U.P.
Fork: 3T Leteus II
Bars: 3T AeroNova LTD
Tape: Lizard Skins 2.5
Stem: 3T Integra LTD
Seatpost: 3T Iconic 0º Team (gave the LBS the wrong pn as I wanted the LTD)
Saddle: Brooks Cambium C15 Carved
Shifter: SRAM RED 10spd
Brakes: TRP Spyre
Crank: SRAM Force CX1
Chain Ring: Wolf Tooth 44T
Cassette: SRAM XG-1080
Chain: KMC XS10SL DLC/BLACK
RD: SRAM X9
Cages: Arundel Mandible
Pedals: Speedplay with Ti spindles
Wheels: Kinlin TL-23 27.5", BHS MTB hubs, Sapim Laser
Tires: Schwalbe Thunder Burt 27.5x2.1"
gb123bike
by gb123bike
My commuter is about 11.8 kg / 26 lbs with the rear rack, but without fenders and panniers. That's a long ways from the lightest thing out there for sure, but it wasn't too expensive and has lower tier parts. My pannier set adds another 1600g dry, but I normally stash some bungies and other random items in there making them more like 2000g empty. I could probably look for lighter panniers, but by the time I've got a week's groceries on the bike, I figure it doesn't matter too much any more.
Not sure how much my fenders weigh. I only put them on in foul weather. They're plastic ones from PB or somebody but they're wide enough to clear Nokian studded winter tires. Invaluable in the muck.
Pretty happy with the setup. Would like it to be a little lighter though for those times when I don't have the panniers mounted and just want to crest the hills between house and work.
zmjones
by zmjones
about 22.5 minus the bottles, mud, and lights (but with the taped on tube) Image
think it is a bit less now. running a slightly lighter wheelset (that one is 32/32 and normal one is 28/32) w/ g-one speed 35mm instead of 38mm ars, have slightly lighter bars, and an rx rd w/ an 11-34 instead of the tanpan/xtr sgs/xt 11-40 shown here. great for commuting in seattle winter though.
JMeinholdt
by JMeinholdt
Currently at 8.46kg. As I lighten up my Wilier, some of my parts that don't sell may turn into hand me downs for this. Already planning a CF handlebar upgrade for that reason.
Wilier Cento10AIR Rim Brake - SRAM Force AXS
3T Exploro - SRAM Rival AXS XPLR - Gravel/Commuter
Strava link: https://www.strava.com/athletes/jmeinholdt
YouTube link: https://www.youtube.com/@JMCyclingVideos
froze
by froze
I commute on a 1984 Fuji Club that I made some changes to. The original Suntour ARX derailleur were not the high quality shifting I had come to know from Suntour, so after much fiddling with it to make it shift better, I gave up and switched to Suntour Superbe Tech on the rear and Superbe Pro on the front, when I did that, I also put on Suntour Superbe pedals, this was new stuff I had in storage since 86 or so. Now the shifting is amazing. I know the internet is abuzz about how bad the Tech stuff was, but that has not been my experience, I have another bike with the same stuff on it that I put over 150,000 miles on it and the Tech rear derailleur is just fine after all those years and miles; I think the rear Tech derailleur was the best friction derailleur ever made except for the weight, but that's a non-big deal since it shifts even better than the Superbe Pro rear derailleur I had. I then took out of storage a lightly used set of Torelli Master Series Rims I had built with DT comp spokes and Suntour Superbe hubs and replaced the original Ukai rims with those. I'm thinking of taking the Superbe brakes and levers off the 150,000 mile bike and put them on the Fuji, maybe this summer. I took off the original yellow plastic handlebar tape and have over the years used nothing but yellow cork tape. Of course, the seat has been replaced with a Fizik white saddle with red accents, though I would like to find a yellow saddle. The bike's paint and decals are still in excellent condition since I haven't ridden it much for many years till the last 5 years I decided to use it to commute on. It's a great riding bike though.
While for whatever reason I can't post an actual photo, or a on line photo, so just go here: https://www.bing.com/images/search?q=19 ... HoverTitle
