Anyone tried the Fulcrum RACING QUATTRO CARBON clincher
ferrarista
by ferrarista
PrimO wrote:
What is going on at the bottom of the wheel? It looks like the braking surface is running into the wheel section??
Looks like reflection from the flash. The 3k carbon does drop down a bit more , but nothing like in the pic and its not noticeable in natural light.
ferrarista
by ferrarista
norcimmus wrote:It took me roughly 3 days (1-2 hours dedicated per day once my fingers/hands fatigued) to fully remove the stickers on one wheel, whatever Fulcrum uses for the glue is stubborn. Essentially the plastic logo layer of the stickers came off but the sticky reside resided on the wheel.
A mixture of acetone, diesel fuel, time and elbow grease finally got it all off. With the amount of effort it required, I NOT going through the same pain to remove the stickers on the rear wheels.
It only took me about 30 minutes per wheel. Taking off the stickers didn't take long. Its the residue that takes the longest, but I used some product we have at work which I don't recall now. It worked much better than acetone. It dissolved the sticker residue quickly and doesn't harm clearcoat finish, etc... I will find out on Monday what it is.
By the way your bike looks much better without the stickers. I just find they went overboard with the stickers. I normally don't like stickers on wheels.
sawyer
by sawyer
Got a set now ... they are really nice. Not outstanding in any respect other than VFM, where they really are a steal vs Zipp/Mavic etc ... ok, slightly inferior hub, but in other respects they are they equal of wheels 60-70% more expensive IMO
If you are on Campag, and can get the Bora One 35s at a good price, I still think they are a better wheel, and better VFM, but these aren't far off
ferrarista
by ferrarista
The product I used to take off the stickers residue is called ZEP Power Solv 5000. It is available in gallons , but it is also available in spray can.
https://www.amazon.com/ZEP-PowerSolv-5000-Solvent-Degreaser/dp/B00H03E5BK
Pretty good product to take off residue, but expensive. Dries fast. I used that , followed by disinfectant alcohol and buffed with a microfiber.
ClydesdaleChris
by ClydesdaleChris
You guys pulling stickers off with solvents etc know that heating up those decals with a hair dryer, until just hot to touch, means that they stickers come off without any effort whatsoever, and very little cleaning required???
BandiCoote
Eddy Merckx Roubaix70 custom build
Trek Émonda 2018 SLR
ferrarista
by ferrarista
ClydesdaleChris wrote:You guys pulling stickers off with solvents etc know that heating up those decals with a hair dryer, until just hot to touch, means that they stickers come off without any effort whatsoever, and very little cleaning required???
I tried with the hair dryer, but it seems like the sticker was breaking up even more.
ClydesdaleChris
by ClydesdaleChris
Heat a corner, Lift up the edge, grab it with tweezers, keep heating until the decal peels easy. Pull back on itself, any other way will cause it to break. Use the heat to do the work.
BandiCoote
sawyer
by sawyer
I much prefer them with decals ... Fulcrum is a brand to be proud of ... no decals looks like Farsports ...
That said the water transfer decals on the Boras are so much nicer than these stickers
norcimmus
by norcimmus
I actually left the wheels exposed in direct sun during high noon. The problem is that the residue separates from the actual sticker and remains on the rim. I found it easier to remove the residue when it has been exposed to air overnight, it sort of dried up which made it easier to rub off. When the residue was fresh, it just smeared all over in layers. Imagine it being similar to rolling freshly picked boogers between your fingers to ball it up.
ClydesdaleChris
by ClydesdaleChris
Eucalyptus oil gets the glue off.
BandiCoote
PinaF8
by PinaF8
This is what I use. Basically it's an eraser which you attach to your dewalt power drill. Removed my fulcrum decals with ease and does not damage wheel coating.
S-WORKS VENGE 1ST GEN
PINARELLO F8
PINARELLO F10
2018 BMC SLR01
2019 SCOTT SPARK RC 900
fogman
by fogman
norcimmus wrote:Imagine it being similar to rolling freshly picked boogers between your fingers to ball it up.
Good analogy. Dried up boogers roll much easier.
It's all downhill from here, except for the uphills.
ClydesdaleChris
by ClydesdaleChris
Getting some this week, having to take the ENVE 3.4 loaners off the Domane, so this should be an interesting comparison, like for like tyres etc. should look awesome on the Merckx as well. Not sure which bike will wear them more!
BandiCoote
PrimO
by PrimO
ClydesdaleChris wrote:Getting some this week, having to take the ENVE 3.4 loaners off the Domane, so this should be an interesting comparison, like for like tyres etc. should look awesome on the Merckx as well. Not sure which bike will wear them more!
It'll be nice to get a like for like comparison!
ClydesdaleChris
by ClydesdaleChris
Haven't ridden them yet, but 1450g. IDENTICAL weight as the ENVE 3.4.....
Seem well made, hub is a matte finish which some may say is a negative but they're well made and everything seems solid. Bearings stupid-smooth in the hand. Fulcrum/ Campagnolo freehub switch went well, I run Record 11s and the freehubs of all Fulcrum/ Campagnolo are interchangeable down to Vento/ Racing 5.
Quality brake pads and a very satisfactory brake action, with the rough bedding finish of the pads and the 3K brake track. I'm confident it will be streets ahead of the previous generation smooth-track and soft pads of old.
This should get interesting....
BandiCoote
